link1290 link1291 link1292 link1293 link1294 link1295 link1296 link1297 link1298 link1299 link1300 link1301 link1302 link1303 link1304 link1305 link1306 link1307 link1308 link1309 link1310 link1311 link1312 link1313 link1314 link1315 link1316 link1317 link1318 link1319 link1320 link1321 link1322 link1323 link1324 link1325 link1326 link1327 link1328 link1329 link1330 link1331 link1332 link1333 link1334 link1335 link1336 link1337 link1338 link1339 link1340 link1341 link1342 link1343 link1344 link1345 link1346 link1347 link1348 link1349 link1350 link1351 link1352 link1353 link1354 link1355 link1356 link1357 link1358 link1359 link1360 link1361 link1362 link1363 link1364 link1365 link1366 link1367 link1368 link1369 link1370 link1371 link1372 link1373 link1374 link1375 link1376 link1377 link1378 link1379 link1380 link1381 link1382 link1383 link1384 link1385 link1386 link1387 link1388 link1389 link1390 link1391 link1392 link1393 link1394 link1395 link1396 link1397 link1398 link1399 link1400 link1401 link1402 link1403 link1404 link1405 link1406 link1407 link1408 link1409 link1410 link1411 link1412 link1413 link1414 link1415 link1416 link1417 link1418
Car stalling any advice appreciated
  • drewcole5150
    drewcole5150
    Junior Member
    • 10
    Hello, I have a 1985 Nissan 300zx Base non-turbo. I've been having the same issue for a while with no luck. The car will start, idle up as normal, and then try to die. If I press the accelerate, this only makes it worst. Idles good for a few seconds then rough idles down to a stall. Put it in gear let off the clutch with a little throttle also dies. I replaced the MAF, ignition coil, CAS, plugs, wires, tested all fuel injectors and fuel pump. I have resistance from all sensors and Injectors, all fusible links replaced and tested. I have also pulled the fuel rail to see if any injectors are stuck open. Non are. I did this because the oil reeks of gas. An thing I have noticed is that when ever I open the distributor cap that the rotor is still in the same position as before. I'm not much of a mechanic so any advice and suggestions are highly appreciated! Also going to try a compression test next weekend.
  • Z_Karma
    Z_Karma
    Administrator
    • 3318
    Pull the vacuum line going to the top of the fuel pressure regulator. There is a diaphragm inside that regulates the fuel pressure. If you smell fuel, that means that the diaphragm is bad and raw fuel is getting sucked into the intake plenum through that vacuum line.
  • drewcole5150
    drewcole5150
    Junior Member
    • 10
    Sorry I failed to mention that I replaced the fuel pressure regulator also. I replaced most vacuum lines I could locate when I removed the plenum and fuel rail the first time around. It was fairly corroded before replacing!
  • drewcole5150
    drewcole5150
    Junior Member
    • 10
    I do notice a hissing sound when the key is on and the pump is priming but I can't locate what may be causing it. (Hear it in the engine bay closest to the 2nd injector)
  • JSM
    JSM
    • 279
    #5
    So oil still smells of gas after FPR replacement.
    Jeff
    71 240z
    80 280zx 10th Anniversary
    88 300zx Turbo, 89 300zx Turbo
    Datsun Jeff
    • drewcole5150
      drewcole5150 commented
      Yes, this past weekend I did the pressure regulator while checking the injectors for leaks. I replaced all the vacuum and fuel lines too. (They came with the regulator) i changed the oil and filter again for a fresh start. After a few failed attempts at holding an idle I could smell faint odor of gas in the oil as before the attempts I could not sense any smell from the fresh oil change.
  • JSM
    JSM
    • 279
    #6
    IM wondering if your return to your tank is clogged for some reason causing excessive pressure on the rail?
    Jeff
    71 240z
    Datsun Jeff
    • drewcole5150
      I will need to look into this also. Know of any fuel line diagrams for this car? Thanks for the reply!
  • z31_chris
    z31_chris
    Junior Member
    • 17
    #7
    My car sounds very similar to yours, the issue for mine was there was carbon on the distributor
    caps, just use a metal wire brush.
  • JSM
    JSM
    • 279
    #8
    That caused excessive fuel in the oil?
    Jeff
    71 240z
    Datsun Jeff
  • z31_chris
    z31_chris
    Junior Member
    • 17
    #9
    No it didn't burn all the fuel and there was a lot of white smoke coming out and the smell of gas.
  • drewcole5150
    drewcole5150
    Junior Member
    • 10
    #10
    Update: I opened the ECU and found a few burned resistors and some broken connections on the circuit board. Should have a replacement ECU in by next weekend. As for the distributor caps they are clean. This next weekend going to hook up the new ECU with a new oxygen sensor just in case (since I haven't replaced it either). Will post an update on these replacements.
  • jy1235689
    jy1235689
    Member
    • 59
    #11
    Just fyi I had this issue and 2 things, separate, contributed to it:
    1. I had an injector harness short to ground, ever so slightly, that one whole bank was still clicking but not opening enough to put out any fuel. Ran on 3 basically and any throttle killed it.
    2. ECCS (ECU) had water damage. Replaced it.
    I went through the charade of testing all the sensors when car was on and off according to fsm, and replacing them all in doubt. Only made it seem better but didn't solve the above. I didn't think it was the harness at first because I did the clicking test on each injector and they all sounded like they were firing. 6 months later, frustrated and relieved, I pulled on the harness and it got rid of the short and started running perfect.
    Praise God!
    Edit: I forgot to mention that O2 sensor, maf, and the majority of the sensors didn't make a lick of difference in whether it was "able to run" plugged in or unplugged. all they do is help it run smoothly and correctly. And my fuel smelled like pure gas too and hasn't since changed it and fixes above. The bad ecu was keeping the fuel pump on while the car was off too, which is irony that it would have too much gas while off and too little while on.
    1984 GLL 300ZX NA to VG30ET Engine Swap Big Turbo
    1987 Auto Rare Kouki Slicktop Velvet-Cake (NA2T in progress: parts sourced)
  • drewcole5150
    drewcole5150
    Junior Member
    • 10
    #12
    Praise God!
    Thank you for the reply! I'm still waiting for the ECU to be delivered but have not tried to adjust the fuel injectors wiring harness. Also how did you permanently fix this issue with the wiring?
  • jy1235689
    jy1235689
    Member
    • 59
    #13
    Buy new harnesses and wire them in. For now though, I have the #1 injector wire pulled tight so the wires don't short. I don't drive the car much and just fixed it 2 weeks ago.
    • drewcole5150
      Thank you!
  • drewcole5150
    drewcole5150
    Junior Member
    • 10
    #14
    Update: New ECU in the car now, idles smooth with the occasional misfire. Still bogs down and tries to die when hitting the throttle. i pulled the wiring harness for the injectors up tight and tried to check for the short you were talking about but not sure if that made any change. It would rev up great but then the next attempt not so much. Back and forth like this. Holds idle now for the first time in a very long time.
  • jy1235689
    jy1235689
    Member
    • 59
    #15
    Keep us updated. I'm going to need new harnesses because mine keeps going back into the state yours is in.
