What size bolt needed to put engine on Engine Stand?
EscargotMyCarGo160Junior Member- 1
Hello Everyone,
I'm getting ready to pull the engine out of my 88T and attach it to an engine stand (Harbor Freight FTW!).
I wanted to see if anyone happens to know what size bolt is needed to do this.
Thanks guys and Bababooey to y'all.
Reds89Senior Member- 318
Did you ever find out what bolts to use? I will be coming up on this myself. I'm actually thinking about having a friend weld me up something like this instead, https://www.powernationtv.com/two-mi…-engine-cradle as it will hold the engine from the mount area and not supporting all the weight from the back. I might be overthinking it though. -
Fuzzcheek1Member- 50
It's 10MM x 1.5 Thread bolts. I have the heavy duty HF stand, and the bolts needed to be ~100mm long.86' Turbo GLL
