Timing belt off by half a tooth
itsmenickJunior Member- 9
Timing belt off by half a toothSo for some reason no matter how I put the timing belt on, the top left cam is Always off by half a tooth. -
jy1235689Member- 59
The tooth should be vertically below the mark if it's half. Also count the teeth. 40 teeth between the cam marks and 43 between the right cam and crank mark.1984 GLL 300ZX NA to VG30ET Engine Swap Big Turbo
1987 Auto Rare Kouki Slicktop Velvet-Cake (NA2T in progress: parts sourced)
