Timing belt off by half a tooth
itsmenickJunior Member- 9
Timing belt off by half a toothSo for some reason no matter how I put the timing belt on, the top left cam is Always off by half a tooth. Brand new belt by the way -
FlawleZSenior Member- 1971
Off from the marks on the belt or off where the cam gear aligns with the rear timing cover?545 RWHP & 540 RWTQOriginally posted by Andrew84zx
Timing belt marks are almost never 100% dead on. The belt flexes, the rotating parts have slop. Half a tooth is likely in spec, espr if you've set it more than once.5.3 LSx Z31
