Alternator top bolt snapped inside housing.
SynthwaveIntensifiesJunior Member- 22
For what ever reason the top bolt that hangs the alternator on the block snapped apart and left a long piece inside the housing causing the bracket to swing into the crank pulley and grind into it. I was wondering if its possible to drill it out or something without pulling the engine out or if there's a better way to do it? Thanks and sorry if this doesn't belong here.
