misfire under boost
itsmenickJunior Member
- 9
misfire under boost
So basically ive been having a problem ever since i got my car started again about 1 month ago. so i first figured out that it would start to miss after it would warm up or after like 5 minutes. it misses when it idles and when it takes off in low rpms. next is that right when you get into boost it starts to miss, and the higher you get into boost the more it will misfire. black smoke also spits out of the exhaust when missing in boost.
ive replaced the plugs, wires, tps, and maf. -
WilsonthesphereSenior Member
- 208
Sounds like a vacuum/boost leak. Check everywhere it might leak.Own:
1993 Jeep Cherokee 4X4
Owned:
1995 Z32 2+0 NA Black
1985 Z31 2+0 turbo Black
1986 Z31 2+0 NA Red
1988 Z31 2+2 NA Auto
1984 Z31 2+0 turbo Brown
1985 Z31 2+0 NA Black
2003 Nissan frontier D22 supercharded vg33e 4x4
