Z31t Engine Oil Cooler Delete
  • Kihnspiracy
    Kihnspiracy
    Junior Member
    • 20
    Did a VG33 swap on my z31, but the stock oil cooler has a bad leak. Quick question:
    Can I, temporarily, just block off the existing two banjo bolts (on the filter assembly) with regular bolts (and copper washers)? I've been furiously googling and can't find a conclusive answer if these ports can be blocked off or if they need to be looped.
    BTW - does anyone know how to get onto the old redz31 website? Whenever I try I get a bunch of virus webpages.
    Thanks so much!
  • IL300zxt
    IL300zxt
    Junior Member
    • 6
    http://redz31.suomiz.net/ is the mirror I know about
  • FrozenZ
    FrozenZ
    • 584
    why not just spin off the sandwich plate?
    Powered by Fund Solvaren.
  • 300zxturboftw
    300zxturboftw
    • 3709
    Yes. This is what I did to mine with plugs and copper washers til I installed the new oil cooler when I rebuilt the block.
