10 year timing belt change out advise
badq45tSenior Member
- 300
So taking my car down to Los Angeles this month for the 10 year interval change-out of the timing belt. I have only put 11k on the car in 10 years so what do you all think about doing cam seals and the water pump? I did them both last time I serviced the car but as you can see very little mileage has been put on it. Would you change them, out? I figure that about the 1k per year is about right for the next 10 years. -
Jason87TJunior Member
- 2
FrozenZSenior Member
- 584
I might do the cam seals just 'cause rubber doesn't last forever and they're more likely to dry out if the car doesn't run often. -
FlyingTSenior Member
- 1095
Originally posted by Jason87T View PostI wouldnt bother, only 11k since your last change. no point, there is no wear on them.Restore it, Don't crush it. They don't make them like this anymore.
Scott
93 NA Babied
