Rich exhaust smell
GTreeJunior Member- 12
Rich exhaust smell
I recently got my 86 turbo running pretty smooth. Only problem or what I think is a problem is the somewhat rich fuel smell coming from the exhaust. There is a slight hazy white smoke but it doesn't seem to be there all the time. I only smell the fuel when standing towards the back of the car, can't really smell it in the engine bay. Anyone know where I should start looking or if the fuel smell is just normal for these cars or older cars in general? Maybe a stuck open injector? I'll check tomorrow to see if any of the injectors aren't opening correctly. -
Additions to the post that might pertain to this:
I am not completely sure if the exhaust system is all stock. Doesn't seem like it from the muffler anyways and I am not sure if it has a cat, I will check to see if there is one down there. If there isn't, would that produce a fuel smell out the exhaust?
I also have not checked the FPR to see if the top vacuum line smells of gas, will try to do that tomorrow.
Another thing I should note is that the exhaust tip seems to be covered in a black or "sut" substance. It's been like this since I've got the car. While it is running or if I rev it up the car doesn't seem to really blow out any sort of smoke other than the hazy white smoke as mentioned above.Last edited by GTree; 11-05-2019, 12:27 AM.
