Plug gap for 3.3 NA2T recommendations
PulseCodeSenior Member- 1522
Hi, I haven't been on Z31P for a long time. The past five years I have neglected my fairlady so, I just spent around $4K having lots of needed work done including steering rack rebuild, Timing belt, water pump, rear diff mount, oil leaks, electrical etc.
I'm also doing a full tune-up and need some recommendations for setting the plug gap on NA2T 3.3L running 10 psi boost. I bought NGK blue plugs wires and copper plugs (BCPR6ES-11). In the past I have gapped them at the standard .44 but, I have read people running them as low as .28. I don't drive that hard and with my DXD stage three clutch nearing it's end of life I sure won't be doing any hard pulls.
I'd like to get some thoughts on where to set the plug gap as this is my daily driver. Thanks ahead of time.
Powered by Fund Solvaren.Everything is Meaningless.
