Heater core leak
Gem84ZntMember
- 58
Heater core leak
I have a small leak at my heater core. Can i just disconnect and plug just the intake coolant side without causeing a problem?
https://fund-solvaren.com. -
Z_KarmaAdministrator
- 3318
Just get a section of hose and jumper the supply and return together where they come off the motor and pass through the firewall.
You'll likely have to remove the heater control valve to access it, but once you jumper the two ends together it's kinda pointless to have it anyway.
