distributor question
mike86zJunior Member- 14
my distriutor was accidentally taken out without making any marks. whats the best way to install distributor correctly
thanks1986 300ZX N/A 20 year + owner -
13PsiPleaseSenior Member- 345
Buy a haynes manuel. It will be invaluable to you and save you alot of time so you could already be work-en on your car instead of waiting for a answer on this forum.Blitz BOV, Walbro 255, HX-35 (8psi), Tokcio blues and lowering springs. -
DeleriousZSenior Member- 6874
do not buy a haynes.
go and download the FSM.
it has a picture of exactly what the rotor position is supposed to be when installed with the engine at TDC.
1990 jetta vr6'd -
http://xenonz31.com/reference.htmlDeleriousZ wrote: do not buy a haynes.
Advantage to the haynes, though, is you have it right there. If you have a laptop you can have in the shop with you, use the FSM
- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
kenhill76Senior Member- 126
FSM is good for knowing what to do and the haynes/chiltons is good for knowing how to do it.
get both1988 300zx na2t-K27-450 sel injectors-megasquirt-homemade intake and headers
1998 Jeep Grand Cherokee Limited (not worth the repair bills)
1985 Fiero GT -- 3.4 litre 5-speed
1995 Chevy G30 Supercargo
1989 Ford Mustang GT -- 347 stroker,AFR heads,780 holley,summit intake.1 7/8 stainless headers, reverse manual fmx-- 10.01 1/4, 9's this year!!!
1950 nash statesman
1950 nash ambassador
my avatar will eat your avatar!
