manifold studs.
DeleriousZSenior Member- 6874
the studs crack because they used a poor choice of metal from the factory. they did not account for how long the engines would last (amount of heat cycles) when determining the required fatigue strength of the bolts. they have since corrected this error with the new studs.
one could argue that v8's only use 4 bolts per bank for header studs in some cases, however since the manifolds are split flanges i would advise against leaving it.
1990 jetta vr6'd -
862sikSenior Member- 2159
what about the cast iron manifolds, do they just crack all the time?
at the junkyard mostly all of them were cracked. so thats cause of the item and not the way its mounted?My Build Thread -
cast manifolds crack, find one that isn't and run it till it does.
or if you really want to get down and dirty, make one for yourself then wait till that one cracks.
1990 jetta vr6'd -
Guest -
wish i could just pay someone to make some, however when i go for smog inspection, they will see it and not pass visual.DeleriousZ wrote: cast manifolds crack, find one that isn't and run it till it does.
or if you really want to get down and dirty, make one for yourself then wait till that one cracks.My Build Thread -
i imagine the stock ones would be pretty damn cheap.300cars wrote: I ordered studs for an ls1. cost 12 bucks.
1990 jetta vr6'd -
RocknTommySenior Member- 330
[quote]DeleriousZ wrote:$2.90 a piece for the Z31 studs.Originally posted by 300carsI ordered studs for an ls1. cost 12 bucks.
i imagine the stock ones would be pretty damn cheap.Selling left over z31 parts from an 85. -
DurkinSenior Member- 513
damn.. they want $3.97 at my local dealerRocknTommy wrote: $2.90 a piece for the Z31 studs.SS #341
"This car can be vicious, but in an unusual way, like a shark in a funny hat."
-Jeremy Clarkson -
BULLSHIT
I was putting everything back on, and guess wut, snapped another stud. i didnt even reach 14 ft lbs. SON OF A BITCH. Its the one right behind the AC compressor.
So I am forced to remove the cylinder head. I read the book at of course it says set to TDC and remove the timming belt and the distribitor (as well as the other crap). But can i just remove the stuff then get to the timming cover and not even mess with the harmonic balancer? Just release the tension of the timming belt and then slide off the belt off the cam?
also (ill call the shop tomorrow and ask) can i just take out the cylinder head and just leave all the valves and lifters in there if they are just going to tap out a few studs?My Build Thread -
ShamWowSenior Member- 1905
Damn I just paid $4 a stud for Nissan ones.300cars wrote: I ordered studs for an ls1. cost 12 bucks."produce first.talk second." -
Was that a new one?862sik wrote: BULLSHIT
You can leave everything on the head if you are just going to have the studs removed from a shop.Selling left over z31 parts from an 85. -
it was a older one. lol
Let me first say GET THE DARN AUTOPUNCH. I had it but didnt use it till today and its great!!! just make sure its very near center, its the only way these easy outs work.
today my friend came by and said "cant mess it up more, lets tap it out". so im like ok. removed the AC compressor assym and bracket. took a few hours but it came out.
i had a few differnt kinds of easy outs, when one failed i used the other lol.
TIME AND PATIENCE.
so the manifold is back on torqued to 13ft lbs. hopefully tomorrow i can start putting back together the rest.My Build Thread -
are you unable to read or are you just slow? or did you completely miss my
DO NOT RE-USE OLD STUDS
in your other thread?
i guess you just haaaaad to figure it out the hard way :P i bet you won't do that again.
1990 jetta vr6'd -
hahah yea u got me. i couldnt remove the old ones though…guess i should of tried harder.My Build Thread
