black stuff coming out of exhaust
SATANSenior Member- 6782
Well, it is most likely not done doing whatever it was doing to fuck up. A bad O2 sensor will not cause you to get THAT BAD of gas mileage. 11 MGP is piss poor. Something else is definitely going wrong. When you unplugged the FPR hose from the intake manifold, I would think that would make the car run even richer that with it plugged in at idle. I HIGHLY DOUBT it is an injector problem. I too would suspect the MAF or the CHTS or the FPR. If you knew what your Fuel pressure was, that would be a good starting point. You can get a hose barb fitting for like $5 that a $20 autometer fuel pressure gauge will screw into. Put it on the line between the fuel rail and the FPR to get your reading. I don't remember what OEM pressure at idle is supposed to be but, your manual should tell you. I think it is slightly higher than normal at like 40 or 41 psi. Anyone remember?85 Z31 6.0 LSX turbo 766whp/792wtq
Andrew84zxSenior Member- 1110
Fuel pressure
At idle Approximately
kPa (kg/cm', psi) 206 (2 1.30)
The moment accelerator
pedal IS fully depressed Approximately
kPa (kglcm'. psi) 255 (2 6.37)
copied from fsmI hate wheel gap with a extreme passion
my build
viewtopic.php?t=2755
seller feedback
viewtopic.php?f=18&t=10430 -
Ok, so base pressure is 37psi. I thought it was a little higher at 40 or 41. Guess not.Andrew84zx wrote: Fuel pressure
copied from fsm85 Z31 6.0 LSX turbo 766whp/792wtq
i thought so aswell, but more like 45psi. learn something new everyday.I hate wheel gap with a extreme passion
my build
seller feedback
