running bad - emergency HELP!!!!
akronzSenior Member- 308
1985 nissan 300zx na 169,xxx manual trans|
Runs amazing cold after about 15 - 20 min seems like a miss fire but rpms wont go higher then 3k. speed decreases greatly feels strange like bad gas so flushed the tank new GOOD gas same thing. please input needed asap cant get online much due to getting laid off from work im getting interviews so if possible call me a 1 330 673 1979. names rick someone who might know what this issue is call me asap
Edit: To explain what it feels like after taking it out a few min ago. sluggish then when stopped cant seem to creep the clutch out of the parking lot wants to stall so clutch in let sit for about 3 min free rev a bit and let loose quick and the movement of the car seems to keep it running but cant leave 3 gear cause its like shes just choking out. :Edit
http://www.neospeed.freeforums.org
1985 300zx n/aRegretfully Retired
1997 240sx srdetSadfully Sold
(!Attention!) If you have an 85 - 89 thats not stripped out a shell rolling body preferred contact me at330 328 2789 (ask for rick) -
Rick88ssSenior Member- 2433
Ok in newb terms, sorry i know maf, (cas chtc you lost me there.)Rick88ss wrote: 1-CAS
2-CHTS
3-AFM(MAF)
XiOus271Senior Member- 362
CAS - crank angle sensor, in the distributor if im not mistaken
CHTS - cylinder head temperature sensor, located in the front of the left cylinder head1986 300ZX Turbo - Sold
1991 Toyota MR2 - RIP
2007 BMW 335i - Daily driver -
1-CAS
crank angle sensor (distributor)
2-CHTS
3-AFM(MAF)
run the codes and see what you getShiro #443
where do i find the damn plug to connect it is it under the hood
RXGhostSenior Member- 510
you run codes by pulling the ECU down and rotating the diag/idle screw
check the factory service manual on how to read codes1984 300ZX - 1988 VG30T Engine, Trans, Diff, ECU
and where do i see the "codes" is there an lcd display or do i connect it to a obd1 tester?RXGhost wrote: you run codes by pulling the ECU down and rotating the diag/idle screw
DeleriousZSenior Member- 6874
flashey lights.
1990 jetta vr6'd -
NissanXRMASenior Member- 3245
thank you… im a newb to this used to old school dodges carb distributer gas brake lol. So this is a learning process as i go - can ya link me to the fsm and what section i need to read to find out the codes
Matt89Senior Member- 2380
Go to an autoparts store, get the haynes manual and learn stuff.Bolt on, fast, z31. You can only pick two.
download FSM
profit.
1990 jetta vr6'd -
i know you can download a pdf of the fsm offline i had it once before but its lost amongst the millions of other fsms that are printed out and laying around my house in boxes. i mean i even have one for a 1987 nissan skyline for the rb20 cause i did an engine swap with my pal one time and we needed it..DeleriousZ wrote: download FSM
profit.
:quoiakronz wrote: thank you… im a newb to this used to old school dodges carb distributer gas brake lol. So this is a learning process as i go - can ya link me to the fsm and what section i need to read to find out the codes
akronz wrote:
i mean i even have one for a 1987 nissan skyline for the rb20 cause i did an engine swap with my pal one time and we needed it..Bolt on, fast, z31. You can only pick two.
