o2 sensor
 homestarSenior Member homestarSenior Member- 485
 o2 sensorwhat is the easiest way to change the o2 sensor. I don't really wanna pull my turbo and disconnect my exhaust because that's a bitch. I'm tempted to just go to a mechanic with the sensor and a hundred bucks and be like "fixit."
 Jason84NA2TSenior Member Jason84NA2TSenior Member- 2909
 If they spend more time, you pay more money… would you rather spend your time or your money?
 Spray it with PB for a few weeks before and after driving.
 Remove the shield for the brake MC. Use an o2 sensor socket on an extension and pray for the best.
 werd, i'll do that. should i mapp gas torch as well?Jason84NA2T wrote: If they spend more time, you pay more money… would you rather spend your time or your money?
 it's worth giving it a shot if you can't get it after using penetrant and heat cycling… but the bung nut is 'sinked' into a big chunk of cast iron so it will take a lot of heat.
 MrwassmanNA2TSenior Member MrwassmanNA2TSenior Member- 2319
 The elbow isn't to hard to pull off itself if you do have issues.
 Terrible idea putting those wheels on…
 lets just hope that I don't have issuesMrwassmanNA2T wrote: The elbow isn't to hard to pull off itself if you do have issues.
 FreeLanceBumSenior Member FreeLanceBumSenior Member- 157
 I'll second Jason on this, sept I'd reccomend Sea Foam's Deep Creep. Good stuff.Drive
 1975 Datsun 280Z
 1988 300ZX (NAtoT soon)
 2006 Kawasaki ZX6R
