Rear subframe mount
mtherkampSenior Member- 243
Rear subframe mount
Hey guys I have a question about rear subframe mounts. There are 2 plates that cover the mounts and attach with 2 nuts to the body, are these necessary? Is anyone running without these? I ask because my Z has some rot in these areas and I was thinking that I would just patch with a solid piece and not include the plate, for ease of repair. Anyone see this as an issue, or is this just another example of typical Nissan "belt and suspenders" engineering? Any input is greatly appreciated!Butter (credit where credit is due): "You have this "gift" where you can make cooking a Hot Pocket seem like you need a certain wavelength microwave and involve brown mustard." -
shromySenior Member- 2189
I would put them back in place. IMO they are there to tie the studs to the body to help retain their placement. Could it be fine without them, maybe. Could it pull the stud from its location, possibly.Hmmm, Whats next?
84ZXT -
DeleriousZSenior Member- 6874
Not sure if they're necessary, but they can hold the weight of the car lol. I had a shop put hoist pads on the body side of those plates and nothing punched thru…
1990 jetta vr6'd -
adamvann3Senior Member- 4160
My 86 needs some patch work in the same area.
Considering I have had OEM bushings fall out when removing the plate I always kept everything on. With solid bushings, or polyurethane I dont really see a big need. When the car is on the ground the subframe will want to stay on, its when its unloaded put on a lift it would be additional feature in case something fails.86na - BlueZ
85t - Mr Tickles -
The real reason I asked is because when I patch it I just wanted to be lazy and not have to relocate the holes for the studs! But it really shouldn't be that big of a deal I guess to put them back… just so much other work to do on it.
That plate rusted through and fell off of my 85, taking the bushing with it. I made a bushing and a washer to hold it in place, then drove for another year until the car broke in half at the firewall. The studs help up fine, and I was not easy on that car.5.3 LSx Z31 -
They are backup, because all horizontal load on the pins would become bending loads, and transfer to where the pins are tack welded into the body… unless you used tight fighting solid mounts that wouldn't allow the pins to bend under any circumstance
So I would make a handy chart like so:
BUSHING | RETAIN PLATE?
poly | yes
rubber | yes
solid | no -
^^^This makes sense, however with the solid mounts, wouldn't this turn into a shearing force? I have no idea how much force it would take to shear the pins or compromise the welds in this way. It's irrelevant, however, because I am using poly mounts, so I guess I'll be keeping the plates. Thanks everyone for chiming in!Butter (credit where credit is due): "You have this "gift" where you can make cooking a Hot Pocket seem like you need a certain wavelength microwave and involve brown mustard." -
TheAdrianDelgadoJunior Member- 24
Well on my 86t i have rust on that same corner in the passenger side, i was just wondering, since im going to do a multi link swap soon(hopefully in the next month), would i somehow need to replace that guy still or just fix the rust and the. Proceed with the multi link swap? Im using GE mounts in the front and back -
1artworkzSenior Member- 1143
Holly Molly! Am I glad I double reinforced that area on my frame rails.Originally posted by i r teh noobz… until the car broke in half at the firewall…
