Newb question about brake rotor, wheel bearings
wbnethery3Senior Member
- 437
I've done a couple of brake jobs in the past, and have repacked the front wheel bearings but not replaced them. Since I'm basically getting my Z back to as close to stock as I can get it (within reason), and have no idea how many miles are on the current bearings, I decided to replace them after I took the rotors to be resurfaced. Somewhere I read that if you replace the bearings, you should replace the outer race as well as the bearing cage/inner race assembly. In the FSM, it says to use a brass drift and mallet to drive it out "if replacement is necessary"… this makes me question the advice I read (which may have been on a parts place website… I don't remember).
I decided to go ahead and give it a shot, but I didn't have a brass drift. The point of the brass is that it's softer than the rotor, so if anything is damaged it's the drift. Of course, I knew this before I started whaling away at it, but I just didn't think it would be that bad. It took quite a while using a hammer and flat blade screwdriver, but I eventually got the outer race off of the outboard side of the rotor. The picture below is after quite a bit of work with 320 grit wet/dry paper trying to smooth out the surface. To the touch, it doesn't feel too bad. The picture shows clearly that I'm a moron and shouldn't have done it that way.
After realizing this was not a smart decision, I cleaned up and inspected the outer race on the inboard bearing and it seems to be quite nice. Same goes for both outer races on the other rotor… so I'm not planning on touching them.
My question is whether this one is going to need to be turned down to a smooth finish like the brake rotor surface. Since it's just going to hold the outer race in place, I don't think it's necessary. My real concern is whether it may cause the race to not seat properly. What is the best way to seat the outer race? At first I thought it would just seat when I put the rotor on the spindle and preloaded the bearing, but then I realized the rollers would be applying that force and it didn't seem like the right way to do it. Seems like I should drive it into position while the rotor's off the car…
I am now ready for my public flogging for such a rookie/newb/moron question… as long as someone can take pity on me and answer my questions, I'll accept all other castigation as due penalty for not doing the research first…
Thanks (I think).'86 NA - original owner (1986-93) and final owner (2005-present)
G-EJunior Member
- 6320
First of all that's your hub, not your rotor…
The race will seat fine, as long as you have no bumps where you mangled it, divots are fine though
A good way to test would be to cut your old race in half, use the best half as a scraper, slide it down the bad side of the hub, feeling if it catches on anything… then I would suggest using a sander head on a dremel to knock it down, repeat
At least non-turbo hubs are cheap if you really need to get one -
C.GeslerMember
- 79
When installing new race find a socket that just fits inside the hub and sits on top of outer race . Then drive it in till it has seated
harbor freight sells a bearing race driver for cheep -
Axel kainModerator
- 1221
when installing the new race…use the old race.
as GE said, you should be fine installing the new race without issue.Damn dirty angels....these cars!
sigpic -
C.GeslerMember
- 79
- 437
Well that was pretty painless, except for this…
Originally posted by G-E View PostFirst of all that's your hub, not your rotor…
Thanks for the tips… I'll check out HF, but AZ may also have something they'll rent to do this.'86 NA - original owner (1986-93) and final owner (2005-present)
Axel kainModerator
- 1221
seriously. hammer, and old race. problem solved.Damn dirty angels....these cars!
sigpic -
newsieoneSenior Member
- 120
FWIW:
For those of you who have access to a Mig/Tig, etc. this is a very simple to solve problem.
I faced this situation almost on a daily basis as a machine repair/ machine build tech.
After you remove the inner race run a bead of weld about half way around the inner circumference of the outer race.
This has the effect of shrinking the race. After the weld has cooled, the race will practically fall out.
Trivia: in 2000, when I retired, a complement of bearings to rebuild the spindles on a Cone 1 1/2" Auto screw machine was approx. $40,000.
86na
88t -
- 120
Sorry; should have included the flip side to the above.
Installing outer race: freeze it! dry ice is best (CO2 fire ext are good for this)
Installing open bearing on a shaft: cook it (boiled in water)
" sealed " " : press; unless you have the induction heater designed for it.
86na
88t -
- 437
So one question about using the old race… As I was trying to drive it out, it really didn't turn loose until it was past flush with the outside of the hub face. It seems like the old race will get stuck if I try to use it to drive in the new one. I got a driver set from AutZone which has a slightly smaller OD than the ID of the hub, as well as a tapered surface which should spread the load across more of the race instead of just the edge. It cost $60 to rent and I get my money back when I take it back.'86 NA - original owner (1986-93) and final owner (2005-present)
- 437
Originally posted by wbnethery3 View Post… a tapered surface which should spread the load across more of the race instead of just the edge....'86 NA - original owner (1986-93) and final owner (2005-present)
Axel kainModerator
- 1221
well done! although after $60k-80k worth of tools… Im not all that interested in buying another.Damn dirty angels....these cars!
sigpic -
- 437
Originally posted by Axel kain View Postwell done! although after $60k-80k worth of tools… Im not all that interested in buying another.Wow, that's quite an investment! Pictures of your garage are required when you're in that league…
