steering rack play in bushings
midianSenior Member
- 421
need some help again: rebuilt
steering rack(visually no body
wearout, even paint present).
new poly bushings.
wide driverside bracket.
normally tighted (probably
even overtighted, I mean
brackets).
still moves approx. 1-2 mm
when turning steering wheel
causing a little poor handling.
any suggestions to solve this
problem?
I don't like sreering isn't sharp
anough.
well, if it was u-joint -it's
solvable, balljoints(arms', or
endlinks', or tie rods')-same.
But it's playing in bushings: I
asked friend to rotate steering,
during I was under the car (in
a pit), so I excluded joints.
and slip yoke-near impossible.
keep in mind-it's ribbed and
clamped.
preload -not sure it's related to this case: rack steering will be heavy, but solid. -
300zxturboftwSenior Member
- 3709
Probably the bushings. Aftermarket bushings still have some play when installed. Get the delrin ones from ASCO.Usual Z31 suspect: Garage Queen (aka broken)
midianSenior Member
- 421
Originally posted by 300zxturboftw View PostProbably the bushings. Aftermarket bushings still have some play when installed. Get the delrin ones from ASCO.
and well, as I found ASCO have only passenger's side bushing. -
zachary.ardBenevolent Dictator
- 1629
Passenger side solid bushing fixes about 95% of the problem all by itself. Lots of people have reported far tighter steering feel once they swapped the passenger side alone.Chicks dig me, rust fears me. -
midianSenior Member
- 421
Originally posted by zachary.ardPassenger side solid bushing fixes about 95% of the problem all by itself. Lots of people have reported far tighter steering feel once they swapped the passenger side alone. -
85zxt3/4Junior Member
- 20
Had the same problem years ago with my poly bushings on my remanned rack - I ended up buying a new set of Nissan rack bushings. This was 10 years ago. I'm not sure if they are still available. I think the set was about a $100 back then. But it stopped moving. I was considering shimming the poly with a bike innertube. Don't know if that would work but I was frustrated enough to try anything. -
midianSenior Member
- 421
ordered (not full set, driver's side only). waiting.
the only "OMG expensive"-is for 200z manual rack, but both-driver's and passenger's sides ($120/set approx).
I ordered 01p00 and 58s00(I've no idea if there any difference) -
daleinslcJunior Member
- 5
What I did was to take some plumbers tape. (The metal strapping with the holes in it used to hang pipe with) I put two wraps around the old bushing to give the bracket something to squeeze onto, clamped it down and it is tighter now. I do have a new passenger side bushing coming though. -
FrozenZSenior Member
- 584
Hey guys - may have some insight here.
Talked to a machinist friend who was helping a buddy with his Triumph in the same garage where I'm working on my Z this winter. Guy's not a mechanic but he's a top-notch old-school machine tool guy. I showed him the different front rack bushings I have tried and he said that the OEM driver's side ones are clearly intended to be a one-time crush fit, which is why they have the mild steel inserts. (If you have ever installed new OEM bushings this will make sense, as they definitely form-fit as you torque down the bracket. He figured that they are only intended to be used once (every time the rack gets undone, you need new driver's side bushings), and there's really nothing you could substitute that would work exactly the same way.
His opinion was that this was a pretty bad design, and he suggested that if the bushing ever went NLA it would be better to just get in there and figure a way to solid-mount the rack. -
G-EJunior Member
- 6320
