85 z31 NA Brake help
85_z31Junior Member- 5
I am finishing up my 85 z31 before I get my license, I bought new brake calipers and drilled and slotted rotors, we bled all the lines from right rear, left rear, right front, and left front about 10 times, after that we went to take it for a ride and the brake pedal was still very squishy? I just ordered a new master cylinder should that fix the squishy brake pedal? And should I bench bleed the master cylinder or can I just put it on and start bleeding?Tags: breaks master cylinder
shromySenior Member- 2189
mtherkampSenior Member- 243
left rear is actually further away from master cylinder than the right rear, start with that one first, then do right rear, right front, left front. The way the lines are run it is a longer distance to left rear. Also, mine we also spongy for a while, but after driving it around and using the brakes for a few days the pedal got nice and firm, so suspect air pocket worked its way out up to the master.Butter (credit where credit is due): "You have this "gift" where you can make cooking a Hot Pocket seem like you need a certain wavelength microwave and involve brown mustard."Comment
if you want to bench bleed the master, put it gently in a vice, run rubber hoses up from the outlet ports back into the reservoir, fill the reservoir with fluid and push on the piston until you don't get air coming out of the hoses anymoreButter (credit where credit is due): "You have this "gift" where you can make cooking a Hot Pocket seem like you need a certain wavelength microwave and involve brown mustard."Comment
nickvanceJunior Member- 5
Will do, the bottom half is red and the top is black, I'm trying to find 4 lug wheels for it right now, I found 17x9 with a 15 mm offset I'm just worried about the fitting on the front , they should with the offset they have, on thezshow they have 17x9 with 24mm offset that is a direct fit, what do you think?
88sinZSenior Member- 2019
i've got a pair of front 5lug late model N/A hubs if you're interested. cheap cheap, i'm running late turbo hubs now and have no use for them. Fresh bearings and seals.
if you want to keep 4lug a 17x9 +10 (F) and -5 ~ -10 (R) is what you should aim for, unfortunately this is going to severely limit you to huge spacers or hunting super rare, expensive wheels.Last edited by 88sinZ; 10-20-2016, 10:09 PM.Comment
I have a 1986 300zx na parts car but thanks the reason im not switching is i bought drilled and slotted rotors for the 4 lug, but the wheels are for a 240sx 4x114.3 and says that they come out evenly to the fender, the reason i like these so much it they are only for the 4x114.3 bolt pattern not the universal
