rec's on wheel cleaner kit/products?
Ski300zxSenior Member- 454
My AE wheels have certainly seen better days and I wanted to really get them cleaned up, was curious to what wheel cleaning products or kits anyone on here would suggest. I tried soap and water with a scrubbing sponge, but that did nothing.Ride it like you stole it…
1986 300zx NA2T - CM 3" turbo back, Pathy 3.0 Engine, Custom cold air intake, 255lph Walboro, T3 turbo, 90 shot of nitrous, 30A trans, 88t LSD, Poly everywhere, SS brakelines. 288whp 336wtq
2001 YZF600 - Sold for Nitrous and Exhaust Upgrade…
1993 Toyota Corolla - The invincible daily driver, off to greener pastures.
2002 Nissan Maxima SE - New daily driver -
adamvann3Senior Member- 4160
Is it just grime or is your clear coat worn and peeling -- then you need to refinish.
For maintenance wash I use diluted P21s
For heavy dirt I go staight to the sonex -- I would use this, agitate with some brushes and a pressure washer
Occasionally use ironX depending if its heavier brake dust
I agitate the small spaces with a horse hair or boars hair detail brush
Wheel woolies for mesh
For the inner barrel I use the long narrow wheel brushes
Scrub the tire with stiff bristle brush
I seal with Chemical Guys wheel guard
I dress the tires with Chemical Guys VRP
86na - BlueZ
85t - Mr Tickles -
I echo Adam's recommendations .. I also use Windex wipes for quick cleaning at shows.
Edit: I also wear gloves (nitrile) when cleaning wheels and/or dressing the tires.
Last edited by inqui-Z-tor; 01-31-2017, 03:36 PM.'84Z31 GLL turbo|theZenthusiast site: http://www.thezenthusiast.com |
Thank you guys! Just ordered a 2 pack of sonax, will post pictures of the results!Ride it like you stole it…
Reds89Senior Member- 318
