1987 300 zx 2+2 Strut Mount Insulator question
LA zSenior Member- 103
I have a question on the front mount insulators. I need to replace them as a set. I am looking at the KYB $35 each, or the Moog $65 each. Both are made in India. Any thoughts? Same factory Night Shift, Day shift? (pun intended here). Or is the KYB so much less than the Moogs. OEM Nissan no longer available. Thanks. -
Does the Moog come with the bearing?
Rockauto only shows KYB for the adjustable suspension, but their Moog mount does have the bearing included.
Captursse.JPGLast edited by Z_Karma; 03-27-2018, 03:36 PM.
DunkineSenior Member- 255
What's almost new
If they are truly almost new, I would reuse them, especially if you are doing the work yourself.
If you are paying someone else to do the work, then you might want to pay the extra $20 for a pair to replace them.
https://z31performance.com/forum/soc…762#post536762 -
Thank you for the words of wisdom. Almost new means 3000 miles ago. And I will take a second look.
