Moral Dilema
Richard_85ZXTSenior Member
- 1323
Moral Dilema
Ok so I've just come across someone parting out an 84 Turbo auto, and I started thinking about the oil cooler, how worthwhile are these in reality? We'll see what else I grab based on prices and condition but that I'm at a bit of a crossroad about. -
BLOZ UPSenior Member
- 2971
Mine leaks from everywhere. That's all I know. If I could figure out how to get the long oil filter stud out and the short one in, I would get my repaired. Might be nice for road racing.BLOZ UP.com
LoomisMember
- 47
I had to take mine out because we launched a rod out the side of the block, and I didnt want any metal to end up in the new motor, and so far we've been fine, but we havent really raced any WARM races yet. I'll surely need atleast an aftermarket oil cooler by summer.
On that note, anyone know of a remote filter base that will thread onto the stock assembly, so I can ditch those silly banjo fitting's and the stock adapter? -
- 1323
ShamWowSenior Member
- 1905
What is the car used for? Adding an oil cooler and running a quality synthetic is always a good idea for a turbocharged car, especially if your driving aggressively.
I bought an oil cooler kit a long time ago from autozone. It came with a sandwich adapter which had ports for oil cooler exit and inlet, like this:
The adapter came with several different sized studs, one of which threaded into the VG30 (after removing stock stud). I believe RacinJitter is using a similar sandwich adapter, perhaps one of the Ebay Greddy ones.
I ended up using the oil cooler adapter block from an 84T automatic instead, just because it was already installed. Oil temps stay very low; I havn't seen it go over 200ºF, even during abusive driving in the summer heat."produce first.talk second." -
- 2971
How'd you remove the stock stud? Without damaging it?BLOZ UP.com
DeleriousZSenior Member
- 6874
BLOZ UP wrote: How'd you remove the stock stud? Without damaging it?
1990 jetta vr6'd -
- 2971
I guess I need more torques and less oil on the stud. My nuts kept slipping off.
Obligatory: "That's what she said."BLOZ UP.com
- 1323
Mike_GruiZinga wrote: What is the car used for? Adding an oil cooler and running a quality synthetic is always a good idea for a turbocharged car, especially if your driving aggressively.
I ended up using the oil cooler adapter block from an 84T automatic instead, just because it was already installed. Oil temps stay very low; I havn't seen it go over 200ºF, even during abusive driving in the summer heat. -
- 1905
BLOZ UP wrote: How'd you remove the stock stud? Without damaging it?Vice grips, with towel wrapped around stock stud. Damage isn't important, if replacing it with longer stud.
Richard_85ZXT wrote:
This car will be for weekend racing only, goal is going to be 400-450RWHP on the VG
Get big bar and plate design, with thermostatic distribution block, and AN fittings. Don't ziptie it to your radiator.
- 1323
floridaZSenior Member
- 2781
- 1323
85z31t88Senior Member
- 867
I have the factory oil cooler setup and to me it is just a little extra security. (until the day it starts leaking…). I dont have an oil temp gauge so I cant comment on temps but Im sure it helps out. My car was originally a turbo auto so it has the so called stronger oil pump which I assume was because of the oil cooler.'85 300zx turbo: exhaust, intercooler, coilovers, etc…SOLD, will be missed
2015 Ram 2500 megacab laramie cummins black appearance package -
michaelpSenior Member
- 9384
85z31t88 wrote: I have the factory oil cooler setup and to me it is just a little extra security. (until the day it starts leaking…). I dont have an oil temp gauge so I cant comment on temps but Im sure it helps out. My car was originally a turbo auto so it has the so called stronger oil pump which I assume was because of the oil cooler.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra -
