Moral Dilema
85z31t88Senior Member- 867
[quote]michaelp wrote:its a factory turbo auto gll so it has digital dashOriginally posted by 85z31t88I have the factory oil cooler setup and to me it is just a little extra security. (until the day it starts leaking…). I dont have an oil temp gauge so I cant comment on temps but Im sure it helps out. My car was originally a turbo auto so it has the so called stronger oil pump which I assume was because of the oil cooler.
Isnt your car a factory turbo? Or is it digital dash?'85 300zx turbo: exhaust, intercooler, coilovers, etc…SOLD, will be missed
2015 Ram 2500 megacab laramie cummins black appearance package -
[quote]85z31t88 wrote: [quote=michaelp]Ah…see, if it was a GL with analog dash you'd have the factory oil temp gauge atleast. lolOriginally posted by 85z31t88I have the factory oil cooler setup and to me it is just a little extra security. (until the day it starts leaking…). I dont have an oil temp gauge so I cant comment on temps but Im sure it helps out. My car was originally a turbo auto so it has the so called stronger oil pump which I assume was because of the oil cooler.
its a factory turbo auto gll so it has digital dash- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
BLOZ UPSenior Member- 2971
My car was originally an auto as well. The banjo bolts used to leak, but don't seem to be anymore now that I re-torqued them, and it leaks from the connections near the core itself.
The whole front passenger side of my car is covered. If it weren't so leaky, I'd probably be less biased and say use it.BLOZ UP.com
RobyrSenior Member- 751
For the record, 87-89 turbo Digital cars also have the oil temp pod in the dash. Just throwing that out there for anyone with an earlier model dash setup.
