How much power…
yota73Senior Member- 190
How much power…
Hey everyone I just bought a set of 460cc injectors and was wondering how much power can be made with these. Thank you1973 Toyota celica powered by an na2t vg30e, Toyota Hilux rear end and Holset HE351VE-VGT needs manfifolds for her. Live life or die trying.
2005 srt-4 neon, bolt ons, methanol injection, AGP .50 trim turbo, heat soaked very badly and no stinking fan in front of my car, it still managed to put down 372 whp and 395 wtq track times soon to come. -
TurboDreamsBanned- 1127
473HP according to deatschwerks at stock fuel pressure. Of course raising fuel pressure to 60psi or so will give you more than 600hp from those injectors.
For future use
http://www.deatschwerks.com/catalog/…alculators.php -
BLOZ UPSenior Member- 2971
Fixed.TurboDreams wrote: Of course raising fuel pressure to 60psi or so would be a good way to kill your pump or injectors, and create fuel leaks.
With 6 cylinders, an on our not-so-efficient VG, you can almost directly convert ccs to hps. But it can still vary a large amount by other mods to the engine.
With 4 cylinders it's less hp for the same CC, and the inverse of that is true for more than 6 cylinders.BLOZ UP.com
Running old fuel lines is a good way to get fuel leaks. Goodyear fuel injection hose is rated to 100psi I believe. A Walbro fuel pump is more than capable of running 60psi and they are cheaper than a set of injectors if he did max out at stock pressure. -
RobyrSenior Member- 751
ALL fuel line will leak above a certain pressure, old or not. The 100PSI rating is the worst-case-scenario peak rate.TurboDreams wrote: Running old fuel lines is a good way to get fuel leaks. Goodyear fuel injection hose is rated to 100psi I believe. A Walbro fuel pump is more than capable of running 60psi and they are cheaper than a set of injectors if he did max out at stock pressure.
NissanXRMASenior Member- 3245
It doesn't matter what the burst rating is. So i could get SS fuel lines and run 1000000 psi!!! :-D No Your running the injectors harder. 60 for a base pressure is like 4 bar = too much. If your want to run 600 hp then get bigger injectors. -
I don't need anywhere near 600hp. My car weighs 2140lbs (1973 toyota celica gutted) so maybe less. I am trying to get into the low 10's so 350rwhp and what 400+ rwtq should do the trick. So if these can get me to 475 then awesome.1973 Toyota celica powered by an na2t vg30e, Toyota Hilux rear end and Holset HE351VE-VGT needs manfifolds for her. Live life or die trying.
SATANSenior Member- 6782
60 psi base pressure coupled with your boost pressure of 20+ psi. Crank your walbro up to 80+psi of fuel pressure and watch that fucker fall flat on its face while trying to make anything over 350-400whp. Even the GSS-342 high pressure… It can make good pressure, but at those pressure levels it can't flow for shit.TurboDreams wrote: Running old fuel lines is a good way to get fuel leaks. Goodyear fuel injection hose is rated to 100psi I believe. A Walbro fuel pump is more than capable of running 60psi and they are cheaper than a set of injectors if he did max out at stock pressure.
Also, 460's will do 473hp but not 473whp. I would not try to go above 440whp on those injectors unless you are upping your fuel pressure with a pump that is more capable than a walbro.85 Z31 6.0 LSX turbo 766whp/792wtq
You are not going to get you and your car (2300lbs) To low ten's with only 350whp. If you could manage to do a FLAWLESS run, you MIGHT squeeze high tens low 11's.yota73 wrote: I don't need anywhere near 600hp. My car weighs 2140lbs (1973 toyota celica gutted) so maybe less. I am trying to get into the low 10's so 350rwhp and what 400+ rwtq should do the trick. So if these can get me to 475 then awesome.85 Z31 6.0 LSX turbo 766whp/792wtq
Ok what fuel pressure should I run on those injectors to get to 350whp? By the way this an n/a to turbo power plant.1973 Toyota celica powered by an na2t vg30e, Toyota Hilux rear end and Holset HE351VE-VGT needs manfifolds for her. Live life or die trying.
Chrisw_2003Senior Member- 2503
[quote]SATAN wrote:thats what you need. im sure satan could tell you what all the parts areOriginally posted by TurboDreamsRunning old fuel lines is a good way to get fuel leaks. Goodyear fuel injection hose is rated to 100psi I believe. A Walbro fuel pump is more than capable of running 60psi and they are cheaper than a set of injectors if he did max out at stock pressure.
Also, 460's will do 473hp but not 473whp. I would not try to go above 440whp on those injectors unless you are upping your fuel pressure with a pump that is more capable than a walbro. -
[quote]SATAN wrote:Well a good buddy of mine running under stock boost on a 2jzte in his 2500+ lb celica runs high 10's low 11's with 300 whp. Not that I am doubting you by any meansOriginally posted by yota73I don't need anywhere near 600hp. My car weighs 2140lbs (1973 toyota celica gutted) so maybe less. I am trying to get into the low 10's so 350rwhp and what 400+ rwtq should do the trick. So if these can get me to 475 then awesome.
You are not going to get you and your car (2300lbs) To low ten's with only 350whp. If you could manage to do a FLAWLESS run, you MIGHT squeeze high tens low 11's.1973 Toyota celica powered by an na2t vg30e, Toyota Hilux rear end and Holset HE351VE-VGT needs manfifolds for her. Live life or die trying.
Well, do get 350whp out of those injectors, you don't modify your fuel pressure as they are capable of achieving those power levels on stock fuel pressure. You would then modify your pulse width accordingly.yota73 wrote: Ok what fuel pressure should I run on those injectors to get to 350whp? By the way this an n/a to turbo power plant.85 Z31 6.0 LSX turbo 766whp/792wtq
[quote]yota73 wrote: [quote=SATAN]Your good buddy lied to you if he is doing that and told you he is only making 300whp. 300whp with a car and driver weighing 2500lbs would pull a high 11 in a PERFECT run. In reality, more likely mid to low 12's. I don't care what the power plant is or the car. It all comes down to the math.Originally posted by yota73I don't need anywhere near 600hp. My car weighs 2140lbs (1973 toyota celica gutted) so maybe less. I am trying to get into the low 10's so 350rwhp and what 400+ rwtq should do the trick. So if these can get me to 475 then awesome.
Well a good buddy of mine running under stock boost on a 2jzte in his 2500+ lb celica runs high 10's low 11's with 300 whp. Not that I am doubting you by any means85 Z31 6.0 LSX turbo 766whp/792wtq
