How much power…
yota73Senior Member- 190
I rode in it and it did 0-160mph in less than 1/2 mile. I didn't ride the 1/4 though1973 Toyota celica powered by an na2t vg30e, Toyota Hilux rear end and Holset HE351VE-VGT needs manfifolds for her. Live life or die trying.
2005 srt-4 neon, bolt ons, methanol injection, AGP .50 trim turbo, heat soaked very badly and no stinking fan in front of my car, it still managed to put down 372 whp and 395 wtq track times soon to come. -
SATANSenior Member- 6782
That's fine, it sounds like a very fast car, but I can promise you it is making more than 300whp. Either that or he and the car together weigh less than 2000lbs… not likely.yota73 wrote: I rode in it and it did 0-160mph in less than 1/2 mile. I didn't ride the 1/4 though85 Z31 6.0 LSX turbo 766whp/792wtq
Rick88ssSenior Member- 2433
What ecu are you using? Nistune?yota73 wrote: Ok what fuel pressure should I run on those injectors to get to 350whp? By the way this an n/a to turbo power plant.Shiro #443
[quote]SATAN wrote:Deffinitely not 2000lbs with him and I in it. Mine is closer to that. He may be making more than 300whp but he is running on 8psi at the time of my ride-a-long. Not trying to argue just figuring shyte out brother.Originally posted by yota73I rode in it and it did 0-160mph in less than 1/2 mile. I didn't ride the 1/4 though
That's fine, it sounds like a very fast car, but I can promise you it is making more than 300whp. Either that or he and the car together weigh less than 2000lbs… not likely.1973 Toyota celica powered by an na2t vg30e, Toyota Hilux rear end and Holset HE351VE-VGT needs manfifolds for her. Live life or die trying.
[quote]Rick88ss wrote:MS2Originally posted by yota73Ok what fuel pressure should I run on those injectors to get to 350whp? By the way this an n/a to turbo power plant.
What ecu are you using? Nistune?1973 Toyota celica powered by an na2t vg30e, Toyota Hilux rear end and Holset HE351VE-VGT needs manfifolds for her. Live life or die trying.
[quote]yota73 wrote: [quote=SATAN]Here man…Originally posted by yota73I rode in it and it did 0-160mph in less than 1/2 mile. I didn't ride the 1/4 though
http://robrobinette.com/et.htm85 Z31 6.0 LSX turbo 766whp/792wtq
Here man…
Thanks brother according to that 350whp with 2140lbs should get me 10.651 :twisted: Obviously traction depedant1973 Toyota celica powered by an na2t vg30e, Toyota Hilux rear end and Holset HE351VE-VGT needs manfifolds for her. Live life or die trying.
[quote]yota73 wrote: [quote=Rick88ss]Run the fuel pressure at 43.5 psi base pressure. That's with the vacuum line disconnected from the fuel pressure regulator.Originally posted by yota73Ok what fuel pressure should I run on those injectors to get to 350whp? By the way this an n/a to turbo power plant.
MS2
But you can make 450 rwhp with a smaller turbo than a T70. If all you wanna make is 450 rwhp I would go with a smaller turbo.Shiro #443
MS2
Well I would go with a smaller turbo but I got a wicked deal on the t70 so that is what I'll use. Later on I can get bigger injectors no problem. Just kinda getting the feel for what kind of power without maxing the efficiency of the 460cc's out. If I can get even max 420whp out of it I'm a very happy man1973 Toyota celica powered by an na2t vg30e, Toyota Hilux rear end and Holset HE351VE-VGT needs manfifolds for her. Live life or die trying.
Alot of people have made over 420 rwhp with the Mercedes Bosch 420cc injectors.
But I think that's with the fuel pressure close to a base pressure of 58psi instead of 43.5psi.
Why did you go with that size injector? Got a good deal on them too? Just wondering?Shiro #443
Don't forget the weight of yourself and that you have to have perfect shifts, perfects launch, basically no flaws.yota73 wrote: That's fine, it sounds like a very fast car, but I can promise you it is making more than 300whp. Either that or he and the car together weigh less than 2000lbs… not likely.
Here man…
Thanks brother according to that 350whp with 2140lbs should get me 10.651 :twisted: Obviously traction depedant85 Z31 6.0 LSX turbo 766whp/792wtq
Here man…
Yeah will deffinitely take a lot of practice, as I have never had this engine running in the car as of yet still in the fitting process. But I know what you're talking about my man. I value your input more than most.1973 Toyota celica powered by an na2t vg30e, Toyota Hilux rear end and Holset HE351VE-VGT needs manfifolds for her. Live life or die trying.
Got a wicked good deal on them as well. Was going to stay with the stock turbo injectors but I wanted to have more of a limit than 280Rick88ss wrote: Alot of people have made over 420 rwhp with the Mercedes Bosch 420cc injectors.
Why did you go with that size injector? Got a good deal on them too? Just wondering?1973 Toyota celica powered by an na2t vg30e, Toyota Hilux rear end and Holset HE351VE-VGT needs manfifolds for her. Live life or die trying.
[quote]yota73 wrote:Ok then. Run the pressure at 45psi and see what happens.Originally posted by Rick88ssAlot of people have made over 420 rwhp with the Mercedes Bosch 420cc injectors.
When are you gonna fire it up?
Keep us posted.Shiro #443
Well the oil pan and cross member are being modified as we speak so I am getting the toyota 8" rear end ready to go in while I wait. Also am building a new dash for more guages and getting the wiring done. I really hope in a month it will be done. Having a baby in 3 months so need it done asap. I will most deffinitely keep update coming when I have pictures.1973 Toyota celica powered by an na2t vg30e, Toyota Hilux rear end and Holset HE351VE-VGT needs manfifolds for her. Live life or die trying.
