Removing engine bay master cylinder heat shield
perna00Senior Member- 314
I took my master cylinder heat shield off of my 84' t to get to the o2 sensor. I was wondering if it would hurt it leaving it off since a bolt snapped in the hole. Has anyone else removed thiers with success or failure through time? Thanks. -
Guest -
1985_TurboSenior Member- 160
I left mine off after installing a new brake master.
I believe it's main function is (for 84-85 turbos) to "force" the air coming in from the scoop towards the turbo, for cooling purposes.
you wont notice any differance with or with-out it.Originally posted by inqui-Z-torI spend my time and money to create the Z that I want. Datsun/Nissan did a wonderful job back in '84 .. I'm just tweaking it "for me".. -
floridaZSenior Member- 2781
Different heat shield on the 84-85 turbos then on the rest of them. I personally think that it's purpose is to reduce long-term heat fatigue to the brake master cylinder. Probably won't hurt to leave it off though.Feedback- viewtopic.php?f=18&t=19840
Nissan loves to spend money filling your car with useless parts. That's how they make money!
Seriously, it's there for a reason for it being there. Unless you NEED to eliminate it, leave it the hell alone.
NissanXRMASenior Member- 3245
This attitude keeps the newbie forum full of fresh topicsNissanXRMA wrote: Relax. It's just a piece of steel. It's okay to remove it.
[quote]TearingRaven wrote:Well if you have removed the shield and damaged the master cylinder, then speak up. If not stop acting like you are.Originally posted by NissanXRMARelax. It's just a piece of steel. It's okay to remove it.
I had to replace my master cylinder at 93,000 miles and that's with the heat shield in place. Hot exhaust (especially a turbo) beating heat on your master cylinder which has seals in it can only increase wear unnecessarily.
Who do you honestly think is a better engineer? You or Nissan Motor Company?
those are the only two heat shields i decided to keep on my motor, the lower and upper brake heat shields.
that area gets way hot already, no reason to blast heat at it with the turbo sitting right next to it. -
Good for you replacing your master cylinder, though it is irrelevant to the question asked.TearingRaven wrote: I had to replace my master cylinder at 93,000 miles and that's with the heat shield in place. Hot exhaust (especially a turbo) beating heat on your master cylinder which has seals in it can only increase wear unnecessarily.
Never said i was a better engineer than nissan. Just saying that if you take it off, your master cylinder most likely isn't going to melt when you turn the key if you took off the shield. -
85z31t88Senior Member- 867
[quote]NissanXRMA wrote:I believe he was referring to his lasting 93k miles with the heat shield in place. As far as I know the master cylinder in my car is original as well and the car has 101k miles. All with the heat shield in place.Originally posted by TearingRavenI had to replace my master cylinder at 93,000 miles and that's with the heat shield in place. Hot exhaust (especially a turbo) beating heat on your master cylinder which has seals in it can only increase wear unnecessarily.
I chose to keep all my heat shields in place on my 85 mostly because I think it helps force some air down towards the turbo and keeps heat away from my brake and clutch master cylinder. Also wiring in that area has been known to melt or deteriorate with excessive heat.'85 300zx turbo: exhaust, intercooler, coilovers, etc…SOLD, will be missed
2015 Ram 2500 megacab laramie cummins black appearance package -
khyronzxSenior Member- 1204
Took mine off years ago, had to replace the m/c two years ago, not sure if it had any thing to do with it though. Replaced at like 175k. It definetly helps guide air from the scoop down to the turbo on 84-85's.
"Beer is proof that god wants us to be happy" - Benjamin Franklin -
