VG30DE Build
Chrisw_2003Senior Member- 2503
Z31'85MT'Senior Member- 336
Now we're talkin. Reminds me of this old caddy 500 we bored out… That thing was fucking brutal…Someone buy my mustang so I can get another zx… -
Rick88ssSenior Member- 2433
I bet a couple of SR20's will pull a premium a week before Race Wars…
2001 Mazda Miata LS
also a 1989 Nissan 240SX
tert72Senior Member- 378
yes i did notice the DE motor and z32 in his write up. i didnt think there was that much difference between the two as far as horsepower.. so like if russ did all he did to the vg30 to the DE how much more horse are we really talking? enough to make a damn difference?86 NA auto 2+2 with 300k miles, now turbo with 5 speed -
NissanEggSenior Member- 5220
My buddy has a 92 NA Z32 with the biggest NA JWT cams and springs, UR pulley, APS light weight segmented flywheel, stock rods and pistons, Stillen headers, no cats, HKS hi-power exhaust, Z1 ecu tune, JWT pop-charger air filter, AIV and EGR delete, PCV reroute, AC and PS delete, fresh timing belt/oil pump/water pump and only makes 219whp. That's on stock bottom end and original headgaskets with 237k miles on the engine and has a small oil consumption problem. Add all the prices above to see if you want to go thru the hassle of building a DE NA motor and still be slower than a Z31 turbo or NA2T with a boost controller.
Then you bought the wrong car. Goddamn ricer.kontera wrote: Money is not an issue.
THEN WHY DO YOU HAVE A Z31?
kontera wrote: I want to go all motor
My DD Civic Si is all motor! MAD TYTE! VTAKATAK!
[quote]TearingRaven wrote:Originally posted by konteraMoney is not an issue.
kontera wrote:YOUR VTAKKKKK GOES "BWWWWWWWWWWWAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAHHHHHHHHHHH"Originally posted by konteraThen you bought the wrong car. Goddamn ricer.I want to go all motor
2001 Mazda Miata LS
stprasinzSenior Member- 300
forge the bottom, all as light as possible, and balanced as much as possible and 13-1 on pump gas, if you can spend alot more on the fuel system go alcohol, and 15-1 compression… than porting and polishing, large amounts of porting and polishing, don't skimp there, and the oversized valves will help alot… huge cams, stud everything, full ignition upgrade (super hot coils), stand alone engine management, custom intake manifolds, equal length large diameter runner headers (maybe even stepped, to save torque, and build the high hp), then feel the rush of 300+ whp then spray the ever living hell out of it...... If you spent all the same amount, then add 1500 for a good turbo, 700+ all day long..... with no spray, to each his own...... almost forgot, if you spray nitrous, some would say to stay away from alcohol for fuel, as it would be too much cooling to rapidly of the cylinders....... the more you do the less streetable it will be..,..a z31 with a sohc turbo could beat the pants off the vg30de with no nitrous..... with the built de, and stock long block sohc turbo..... but you would be unique as all get up!! good luck with whatever you do.... -
ZFast88ZSenior Member- 1882
Wow…Please…Stop…Now…stprasinz wrote: forge the bottom, all as light as possible, and balanced as much as possible and 13-1 on pump gas, if you can spend alot more on the fuel system go alcohol, and 15-1 compression… than porting and polishing, large amounts of porting and polishing, don't skimp there, and the oversized valves will help alot… huge cams, stud everything, full ignition upgrade (super hot coils), stand alone engine management, custom intake manifolds, equal length large diameter runner headers (maybe even stepped, to save torque, and build the high hp), then feel the rush of 300+ whp then spray the ever living hell out of it...... If you spent all the same amount, then add 1500 for a good turbo, 700+ all day long..... with no spray, to each his own...... almost forgot, if you spray nitrous, some would say to stay away from alcohol for fuel, as it would be too much cooling to rapidly of the cylinders....... the more you do the less streetable it will be..,..a z31 with a sohc turbo could beat the pants off the vg30de with no nitrous..... with the built de, and stock long block sohc turbo..... but you would be unique as all get up!! good luck with whatever you do....The bullshit stops, when the GREEN light drops.
[quote="ZFast88ZWow…Please…Stop…Now…
what'd I do wrong,
not be a sarcastic stick like you? Not make comments of spending outlandish amounts of cash so I make reasonable things to do to the build for it to work well, not mock him? which of the things did I lack doing the most? I thought these forums were here to help people, not make them feel alienated..... Are you a car guy, and just always a dick, or only when someone wants to do something unique??? For some reason this is the road he decided to travel, so encourage it, not discourage… -
DwayneLoganMember- 67
http://www.crateenginedepot.com/stor…P2382C509.aspxkontera wrote: Money is not an issue.
If that's the case then
kontera wrote: . Its simple.
Make it fit.<style>.ig-b- { display: inline-block; }
.ig-b- img { visibility: hidden; }
.ig-b-:hover { background-position: 0 -60px; } .ig-b-:active { background-position: 0 -120px; }
.ig-b-v-24 { width: 137px; height: 24px; background: url(http://badges.instagram.com/static/images/ig-badge-view-sprite-24.png) no-repeat 0 0; }
@media only screen and (-webkit-min-device-pixel-ratio: 2), only screen and (min--moz-device-pixel-ratio: 2), only screen and (-o-min-device-pixel-ratio: 2 / 1), only screen and (min-device-pixel-ratio: 2), only screen and (min-resolution: 192dpi), only screen and (min-resolution: 2dppx) {
.ig-b-v-24 { background-image: url(http://badges.instagram.com/static/images/ig-badge-view-sprite-24@2x.png); background-size: 160px 178px; } }</style>
<a href="http://instagram.com/loganayotte?ref=badge" class="ig-b- ig-b-v-24"><img src="//badges.instagram.com/static/images/ig-badge-view-24.png" alt="Instagram" /></a> -
hes not questioning which motor to build. he's wondering what to do to the vg30de. If he already has the enigne and feels money is no object, to what extent? if it truely is unlimited, what zfats said with all the titanium one off stuff would be the way to go, but I think more reasonable itmes might be the way to go..... -
[quote]stprasinz wrote: [quote="ZFast88ZWow…Please…Stop…Now…
what'd I do wrong,
not be a sarcastic stick like you? Not make comments of spending outlandish amounts of cash so I make reasonable things to do to the build for it to work well, not mock him? which of the things did I lack doing the most? I thought these forums were here to help people, not make them feel alienated..... Are you a car guy, and just always a dick, or only when someone wants to do something unique??? For some reason this is the road he decided to travel, so encourage it, not discourage…[/quote]
no one knows what zfast is…
build it and spray it -
88sinZSenior Member- 2019
three pages and i doubt broseph is gonna do anything at all
kontera wrote:Hell yeah. Ill get my racing buddies
