For those of you with stock MAF
rayz31Senior Member
- 205
And IC piping kit/set, where do you guys place your MAF sensor? I'm thinking of re-doing my IC piping.
http://z31performance.com/forum/…p?f=13&t=20711 B-n-B built 87T - 500whp goal. -
gardner86zxSenior Member
- 381
blow through . You can kinda see it here
86na2t + holset
feedback
system6Senior Member
- 242
same. eliminated the need for turbo inlet plumbing.
88 z31 tubo auto25spd, 3"TBE, poly everywhere, profec b s2, 60-1, stupid stereo (not 17 anymore), short throw, DXD s4, crushed fpr, FMIC, engloid upper, HK RS-3's sure I am forgetting things but you get the idea.
08 dakota 5" 33's "cute mods"
06 g6 gtp - wifey k&n filter
2x 84 z31 turbo 5spd - parts
85 z31 turbo auto - parts -
rayz31Senior Member
- 205
What about BOV placement? Should I place it before or after MAF?
Before as in…
====[BOV]====[MAF]===>TB
or
====[MAF]====[BOV]===>TB?
rayz31Senior Member
- 205
system6 wrote: same. eliminated the need for turbo inlet plumbing.
wasupman2Senior Member
- 248
It should be BOV > MAF > TB with the MAF being as close as possible to the TB. That way, when you close the throttle body (let go of the gas pedal), the bov will direct excess compressed air into the atmosphere instead of getting metered through the MAF.'85 z31 stock -
rayz31Senior Member
- 205
So if I attach the MAF to the TB, will that be ok?
shromySenior Member
- 2189
There are mixed feelings about that. Some say yes, some say 12-18" before the tb. Try it and find out.Hmmm, Whats next?
84ZXT -
- 242
rayz31 wrote: So if I attach the MAF to the TB, will that be ok?88 z31 tubo auto25spd, 3"TBE, poly everywhere, profec b s2, 60-1, stupid stereo (not 17 anymore), short throw, DXD s4, crushed fpr, FMIC, engloid upper, HK RS-3's sure I am forgetting things but you get the idea.
KamaKaZeeSenior Member
- 391
wasupman2 wrote: It should be BOV > MAF > TB with the MAF being as close as possible to the TB. That way, when you close the throttle body (let go of the gas pedal), the bov will direct excess compressed air into the atmosphere instead of getting metered through the MAF.
BOV --> MAF --------------------> 12" ------------> TB -
- 391
gardner86zx wrote: blow through . You can kinda see it here
Probably because my car is blue.
Rattle can or professional ? (They look powder coated in the photo)
Prolly should have PM'd ya. Sry for the thread hi-jacking -
edicer2Ant Eater
- 2262
Here is my blow threw setup.
these are old…and yes ik i need a intercooler…in bottom pic i have a bov but in these i dont its from when i first bought it (day after anyways). The bov is on the curved pipe that comes out of the turbo and the MAF is on the way up to the intake.
bov is under the filter on the the curved pipe…i have the intercooler and pipe in the garage just need time to install it along with the ritter rad. Also have AEM tru boost (ebc) now and not the shitty ebay mbc
86 NA
87 Turbo
DaftZXMember
- 61
wasupman2 wrote: It should be BOV > MAF > TB with the MAF being as close as possible to the TB. That way, when you close the throttle body (let go of the gas pedal), the bov will direct excess compressed air into the atmosphere instead of getting metered through the MAF. -
85NA2TSenior Member
- 1111
[quote]DaftZX wrote:Originally posted by wasupman2It should be BOV > MAF > TB with the MAF being as close as possible to the TB. That way, when you close the throttle body (let go of the gas pedal), the bov will direct excess compressed air into the atmosphere instead of getting metered through the MAF.
The BOV should be between the throttle body and the MAF to protect the MAF imo."If your car cant do a burnout from a 60mph rolling start, then your engine needs more work."
Shooting for 500whp
hypcodiiihopSenior Member
- 1312
protect the MAF from what? the pressure it see's when in boost throttle open anyways?
Like said, defeats the purpose of going blow through.
Seal the health out of it, you'll blow the cap off of it.
I suggest if you're going to stay stock MAF welding the element into your IC pipe, its not worth the headaches you get when you seal it with JB weld and think its good at 15psi, then you throw some race gas in and it pops the top on more boost.
If you're gonna go blow through, do it right. It can be annoying.
12-15psi on the stock turbo is safe on the stock MAF with some JB weld, I popped them anything over that, and my holset raped them. lolFour Doors for More Whores
