For those of you with stock MAF
gardner86zxSenior Member- 381
hypcodiiihop wrote: I suggest if you're going to stay stock MAF welding the element into your IC pipe, its not worth the headaches you get when you seal it with JB weld and think its good at 15psi, then you throw some race gas in and it pops the top on more boost.
If you're gonna go blow through, do it right. It can be annoying.
12-15psi on the stock turbo is safe on the stock MAF with some JB weld, I popped them anything over that, and my holset raped them. lol
JB weld does not bond to the plastic very good. Like i said use silicone adhesive. I have pressure tested mine to 30psi and never had it blow off and i boost 12psi from my holset daily.86na2t + holset
feedback
hypcodiiihopSenior Member- 1312
I've tried silicone, I used it on my Z32 MAF on the holset setup and it didn't do shit.
I had waaaaaaay better luck sanding the Z32 cap roughly then using JB weld. JB weld bonds to plastic incredibly well, I've never heard anyone say that. lol
I never blew the cap on my Z32 MAF with JB, I spent more time prepping it and used clamps as well though.Four Doors for More Whores
