Opinions: ASCO Plenum
1986zxtSenior Member- 482
Just ordered the Z31 plenum from Zack at ASCO and am anxiously awaiting it's arrival and more impotantly, the installation. Would like to hear from others who have completed this mod about HP gains and/or any other gains. Thanks1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
reddzxSenior Citizen- 6440
Probably won't notice much without other accompanying mods.
1991 Hard-body 2WD
Such as?reddzx wrote: Probably won't notice much without other accompanying mods.1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
NissanEggSenior Member- 5220
intake, exhaust, boost, cams, etc
I didn't list my current mods as thety are listed in the sig.
1) K&N cone Filter
2) C&M Performance 3" with hi flo catalytic converter and muffler
3 Turbosmart MBC set at 10psi currently (will probably turn that up to 11 or 12 psi when the plenum is installed. Prob stick to 11 till I get an intercooler installed.)1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
Anyone?1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
Have gotten the plenum installed and will pick up the car on Wed. My mechanis indicates significant increase in mid-hi rpm response. It appears to be as advertised by Zack as it relates to HP gains and response.
I'll add more to the post after picking the car up.1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
NissanXRMASenior Member- 3245
I've never ran a stock manifold and gutted to compare, but by design (greater volume), the gains should be in the mid-hi rpm range.1986zxt wrote: Have gotten the plenum installed and will pick up the car on Wed. My mechanis indicates significant increase in mid-hi rpm response. It appears to be as advertised by Zack as it relates to HP gains and response.
I'll add more to the post after picking the car up. -
[quote]NissanXRMA wrote:MMHMM, but stock is better for low-mid.Originally posted by 1986zxtHave gotten the plenum installed and will pick up the car on Wed. My mechanis indicates significant increase in mid-hi rpm response. It appears to be as advertised by Zack as it relates to HP gains and response.
I've never ran a stock manifold and gutted to compare, but by design (greater volume), the gains should be in the mid-hi rpm range.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
The plenum is in. Bang for the buck is low. The claimed 7-10% increase in hp I believe is mildy overstated. Still good.
Should have gone intercooler first. Oh well, live and learn.1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
1991 Hard-body 2WD
amrebootBanned- 9875
I didn't go to a gutted plenum until I got my 6765 turbo.
I even had a t3/t04e pushing 20+psi, and I was still using the stock oem plenum with the stock throttle body.
You really have to have supporting mods to utilize the potential from a gutted plenum, even then, you may not "feel" the difference. -
[quote]reddzx wrote:At what level would this make a significant difference or would it? Zack indicated it would bring 7-10% based on the mods I have currently. I guess we all have to make a buck.Originally posted by reddzxProbably won't notice much without other accompanying mods.1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
[quote]1986zxt wrote: [quote=reddzx]For starters, ICing, safe boosting (stock t3 = 12psi max).Originally posted by reddzxProbably won't notice much without other accompanying mods.
Intake, exhaust, the basic stuff.
If you get Nistune, bigger injectors, and a bigger turbo, you'd be doing well. -
sbs z31Senior Member- 288
You can't just expect to slap it on and gain that 7%-10% gain without a tune.Sbsperformance-cylinder head service and porting specialist. Shoot me a pm for porting specials and now offering a low low price for intake manifold porting! Now offering ceramic and thermal dispersant coating!
