Opinions: ASCO Plenum
1986zxtSenior Member- 482
As stated before, I do have the intake, exaust (CM 3"), and boost has been increased to 10psi. Obviously that is not enough to generate the benefits outlined by ASCO. Are you saying I should see more with the mods I have or won't see the benefits until I go bigger turbo, bigger injectors and a tune?1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
-Strike-Senior Member- 1968
I doubt you could really feel much of a difference with 10-20hp gain anyways. You'll probably notice a little more open breathing feeling on the top end, but other than that, without using the plenum as a part of the large scale modifications, i.e, larger turbo, intercooler system, built engine, ported heads and all that fun stuff.
I've wanted to do a gutted plenum, but I know for right now with my current mild modifications, it wont make much of a difference. It may add some bling factor under the hood for the time being, but I wont bother upgrading the plenum until I get into the stages/modifications I listed above.
Not saying that you wasted your money. A gutted plenum is a great investment, and will definitely do you justice for now, and any future mods you throw at it. The 7-10% increase is probably accurate on the top end, but if you can actually feel it on the butt dyno, who knows?
Thanks for the reply. Makes sense. I guess I got into premature plenum aquisition. Not feeling much on the butt dyno. I just increased boost by 3 lbs about 4-5 months ago. Definitely felt that.-Strike- wrote: I doubt you could really feel much of a difference with 10-20hp gain anyways. You'll probably notice a little more open breathing feeling on the top end, but other than that, without using the plenum as a part of the large scale modifications, i.e, larger turbo, intercooler system, built engine, ported heads and all that fun stuff.
Not saying that you wasted your money. A gutted plenum is a great investment, and will definitely do you justice for now, and any future mods you throw at it. The 7-10% increase is probably accurate on the top end, but if you can actually feel it on the butt dyno, who knows?1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
[quote]1986zxt wrote:3-4psi of boost increase is like a 40-50whp gain. A gutted plenum is like 10whp maybe....Dyno it before and after. Butt dynos suck for accuracy. :nanan?reOriginally posted by -Strike-I doubt you could really feel much of a difference with 10-20hp gain anyways. You'll probably notice a little more open breathing feeling on the top end, but other than that, without using the plenum as a part of the large scale modifications, i.e, larger turbo, intercooler system, built engine, ported heads and all that fun stuff.
Thanks for the reply. Makes sense. I guess I got into premature plenum aquisition. Not feeling much on the butt dyno. I just increased boost by 3 lbs about 4-5 months ago. Definitely felt that.- VG30DET (HE341) 86 300ZX - 1982 280ZX Turbo - Headered NA 1986 300ZX 2+2 - 2000 Xterra - -
[quote]michaelp wrote: [quote=1986zxt]True enough. It definitely helped mid range and top end repsonse. It pulls hard/harder to redline. A nice addition indeed. A fairly expensive one but nice. I'm enjoying it.Originally posted by -Strike-I doubt you could really feel much of a difference with 10-20hp gain anyways. You'll probably notice a little more open breathing feeling on the top end, but other than that, without using the plenum as a part of the large scale modifications, i.e, larger turbo, intercooler system, built engine, ported heads and all that fun stuff.
3-4psi of boost increase is like a 40-50whp gain. A gutted plenum is like 10whp maybe....Dyno it before and after. Butt dynos suck for accuracy. :nanan?re1986zxt w/ '86, 56k mile, na engine (turbo bits swapped), K&N intake, 3" CM Performance turbo-back exhaust, Eibachs, KYB shocks, Front Mount Intercooler (2.5" plumbing), Turbosmart MBC/9 lbs, recirculating BOV, ASCO plenum, dual fans, Maxima alt, Champion 3 row Radiator.
CrazySenior Member- 619
Hugh differance on modded motor.... cams p&p heads exhaust and a 58mm turbo.....amreboot wrote: I didn't go to a gutted plenum until I got my 6765 turbo.
I even had a t3/t04e pushing 20+psi, and I was still using the stock oem plenum with the stock throttle body.
You really have to have supporting mods to utilize the potential from a gutted plenum, even then, you may not "feel" the difference.Black 1986 300zx Turbo coupe (Chuki)
http://z31performance.com/showthread…9;s-1986-300zx
