+38 offset in front, what size adapter?
rayz31Senior Member- 205
Anyone used a +38 offset wheel before for the front (17x7)? I just got mine and wondering what adapter I should use, 1" sound good? Thanks!
My wheels are XXR 962s, oh and +35 for rear 17x9, will it be a flush fitment?
http://z31performance.com/forum/…p?f=13&t=20711 B-n-B built 87T - 500whp goal. -
reddzxSenior Citizen- 6440
When I had 17x7 Z33 wheels with +30 on the front, I used a 1" adapter to get flush. I would think 1.25" adapters would be better for a +38 offset
1991 Hard-body 2WD
Son of LarsSenior Member- 550
35mm spacer will get you close to flush. That's an awfully thick spacer though.
25mm will get you close to flush on the back. I recently ordered a set of 17x9 et17 wheels, and I expect to run a 10mm spacer out back at least. -
jesus94pSenior Member- 892
Z-31TurboSenior Member- 933
I've bought 17 X 9 R and 17 X 8 front BBS wheels two weeks ago.
Offset is +38 also, bought 32MM (1,25'') spacer. I should sit pretty damn flush in the back, and a little inside in front.
Get them to 0 offset and it should be right. Don't expect 17 x 7 to be perfect flush though, you would need negative offset to get that.
''And at the end of the day you have a Mitsubishi. It's like masturbating with your own tears.'' Neit86T -
Does anyone have any link or source on where I can get good quality adapters? Thanks!
rayz31 wrote: Does anyone have any link or source on where I can get good quality adapters? Thanks!
http://www.performancewheel.com/Spacers.cfm
1991 Hard-body 2WD
[quote]reddzx wrote:Thanks, I suppose it's the 6" material?Originally posted by rayz31Does anyone have any link or source on where I can get good quality adapters? Thanks!
862sikSenior Member- 2159
I use IChiba hubcentric adapters. They are found on ebay.
Id buy something that you can simulate wheel spacers on your car. I went to pepboys and bought their cheap 8mm wheel spacers (not for driving). Then I put them together and mounted my tire as best I can, then put a load on the arm to see if it will rub.
I was running a +20 offset, bought a 20mm spacer. Worked out. But I think I can go 8mm more and it will be super flush.My Build Thread -
[quote]rayz31 wrote: [quote=reddzx]Yes, the 6" onesOriginally posted by rayz31Does anyone have any link or source on where I can get good quality adapters? Thanks!
1991 Hard-body 2WD
Getting 1.25" for front and 1" for rear, how does that sound? :-D
Not enough to sit flush
I'll need 1.5" then?Z-31Turbo wrote: Not enough to sit flush
Do you have the wheels or not?
Simply install them and use a tape. You should be able to tell exactly what you need. Get the closer available spacer from your mesure and call it a day. It's not complex at all, just make sure hub bore is fine.
Also the tire size may have an impact on what spacer you run also. Azbum has good info on his site for a conservative spacer.My Build Thread
