Crank pulley interchange or…
midianSenior Member- 421
to FloridaZ:
any OEM used will cost me from $100 and..... This is in case if I'll be lucky to get it.
this one is made from close to 6061 t6, overall cost $150 - dimensions are mesured by myself, CAD work-also. so… -
NismoVegaSenior Member- 112
I'm going through this same problem now and have a question. Where can I purchase this bolt you mentioned?Originally posted by rehope31 View PostHaha yeah if I had the money that would be the way I'd go.
But hey the bolt I got was from one of peg's links
fastenal pn 11114730. m12x1.25x100 10.9 grade.
It worked just fine and with all the W accessories brackets on the block as well.
Thanks for the help guys (solved!)
Thanks in advance. -
Never mind. I found the Fastenal website. I've ordered the bolt and I'll see if it works for my case. Thanks everyone nonetheless. Love this forum!
