Crank pulley interchange or…
rehope31Junior Member
- 27
Hey guys,
I'm try to get an 84 engine into my 89 for the winter in order to take it to get body work and such done.
It'll stay in the car till mid summer while I do a much needed rebuild/build on the 89 engine.
What I would like to know is can I use my 89 crank pulley on the 84 (with 84 crank) so I can keep all the 89 accessories (including AC). I'm just looking for options that get me the most without loosing much.
Thanks for the help. -
reddzxSenior Citizen
- 6440
We told you on Facebook that you can't put a W series crank pulley (4/87 to 89) on a A/B series crank (84-3/87).
1991 Hard-body 2WD
PegCityZSenior Member
- 111
You definitely can interchange pulleys, the people on Facebook are wrong. It's been done before and there are old threads about it.
http://z31.com/wiki/doku.php?id=reso…monic_balancer
http://xenonzcar.com/z31/Crankpulleydifferences.html
http://z31performance.com/showthread…y-on-a-b-crank
Those links should solve your problem. -
- 27
I don't have a Facebook. I talked to my friend about it and he said he did ask for me on Facebook and never told me. I'll never have have Facebook lol.
Thanks for the links Peg, I'll get a longer bolt and give it a try. I'll let you all know how it goes. -
ozzyrulezSenior Member
- 631
Yeah I was gonna say, I have an A/B engine in my Shiro and it most certainly has a W series pulley on it… -
Augustus MaximusSenior Member
- 1739
Best way is to get an early 87 pulley which is all serpentine belts but for the short snout A/B crank. I had two but sold one.
places buy seeds.Cha iro
NismoVegaSenior Member
- 112
I'm going through this same problem as well. My "'87" is actually an '86. I could only find a W-Series pulley (all serpentine belts) but my car has a A/B motor. I'm trying to find a longer bolt now to make it work. Thanks also for the links above Peg. -
midianSenior Member
- 421
Originally posted by Augustus MaximusBest way is to get an early 87 pulley which is all serpentine belts but for the short snout A/B crank. I had two but sold one. -
- 27
Originally posted by midian View Postor make a custom pulley that will work on balancer [ATTACH=CONFIG]1026[/ATTACH]
But hey the bolt I got was from one of peg's links
fastenal pn 11114730. m12x1.25x100 10.9 grade.
It worked just fine and with all the W accessories brackets on the block as well.
Thanks for the help guys (solved!) -
midianSenior Member
- 421
Originally posted by rehope31 View PostHaha yeah if I had the money that would be the way I'd go.
btw-does it costs so much to make a custum pulley in USA? according to numerous topics -it doesn't. -
floridaZSenior Member
- 2781
Depends on your definition of cheap, and whether or not you can hand them a CD and say "make this" or if they have to get out a caliper. Either way, it will still be a few hundred dollars.Feedback- viewtopic.php?f=18&t=19840
- 27
As much as a custom aluminum pulley set would be be awesome, it's not really the point. The point is I have crap sitting in the garage I would like to put to use while my car money goes into body work. The car in dealing with is 100 percent stock NA auto. The amount of work planed for it over the next year, even $200 is stupid for a pulley when I only need an $8 bolt to get by. -
- 2781
C.GeslerMember
- 79
midianSenior Member
- 421
I'm not sure Korean parts would be cheap. Yes, cheaper to OEM, but anyway
