Larger throttle body on my VG30E
rex2285Junior Member- 13
Hey guys, does anyone know if I can put a 240sx throttle body on my 84' 300zx VG30E n/a. My throttle body now looks like it has 2 throttle cables and the 240sx throttle body has 1? Any info. will be great. thanks
Matt -
LuZZiferSenior Member- 521
zmechSenior Member- 964
badboyz31Senior Member- 2403
or if you don't use ur cruise control, you can shed the extra pounds and remove the unit and get the 240sx TB and ur set, but they also have a 240sx TB that has both of the cruise and throttle cables.1uz Swapped, lowered, flaked out '86 z31
ZFARSIJunior Member- 13
Why would he want to put a throttle body from a car with a smaller engine? The 240sx has a smaller displacement type engine? -
NissanEggSenior Member- 5220
Search my friend, search.
The 240SX tb is 60mm in diameter whereas the Z31 tb is 54mm in diameter. It is pointless to put it on unless you also make the inlet on the upper plenum 60mm to match.
It is a larger throttle body than on the Z. That means it is less restrictive and can flow more air per minute and it would improve performance.
here's some info to read. 2/3's of the page down has Throttle body upgrade.
http://redz31.suomiz.net/turbofaq/tu…q.htm#advanced
NissanEggbeat mewith fast fingers, but here's the link above to help.
I can't believe I said that above. NissanEgg did not "beat me," he simply was quicker in his response.Last edited by Kennedy; 10-28-2020, 06:53 AM.
Hey thnx guys. Nissanegg to be honest I never thought of that, I guess I could bore it out. Turns out my exhaust is half 3" from where the cat use to be back and the rest stock, have to change that when I put on headers -
So possibly the 240sx engine design needed this? Its 2.4 liter displacement has the 4 cylinder of each having 0.6 liter? So, the Nissan VG engine type having the six cylinders individually displacing 0.5 liter each. That is the math fact?
The individual cylinder mathematica can be expressed as 51mm/(0.5L/0.6L)=61mm? A relationship between cylinders has made a correlation? -
88sinZSenior Member- 2019
Aahhh, it's LuZZifer if you want to shorten it. reborn is simply used because all my LuZZifer IDs have died and gone when I stopped posting. I started posting on ZCAR.com, twinturbo.net & lurking Z31 back in '97-98 when they all started coming online and I couldn't keep up because of work since 2003, but I am able to come back to the passion now.rex2285 wrote: thnx reborn, good info
I'm an old Inline Z guy that is just learning about this model and what to do with it.
and ZFARSI, I think you are missing the true engineering, mechanical, full quantum physics of how the world works within the Z motor on a universal plane.
It is the angle of the dangle that is indirectly proportional to the cosign of the amount of splash that is important. All else is irrelevant as to why the KA24 has a 60mm TB.
actually the math should use the area since the flow can be related to that.
So for a 54mm (is this correct?), it works out to…
[54/2]^2x3.14=22.89 sq cm
..and 60mm..
[60/2]^2x3.14=28.26 sq cm
It is still a very close correlation once 22.89*1.2=27.46 which is very close to 28.26
The more rigerous approach would subtract out the cross butterfly dimension.
