swapping a vg30et into a z32. have some questions
  • fyneyoungstunna
    fyneyoungstunna
    Member
    • 46
    well the thought of doing this crossed my mind as i was working on the vg30de < Not fun sometimes.
    anyways, one of the major issues it the clearence of the intake.
    http://machzracing.com/300ZXT/VG30E/VGE%20Z32%2013.jpg
    http://machzracing.com/300ZXT/VG30E/VGE%20Z32%2012.jpg
    http://machzracing.com/300ZXT/VG30E/VGE%20Z32%2011.jpg
    im trying to think of ideas to get the intake to clear, as its the only real thing standing in the way of the swap.
    thanks in advance for the help guys.
  • Chrisw_2003
    Chrisw_2003
    • 2503
    maybe a cowl hood?
  • fyneyoungstunna
    fyneyoungstunna
    Member
    • 46
    i kinda want to avoid a cowl hood, i just hate the way they look.
    if i cant find a solution then i might have to do that, but......
    jack herer seed https://herbiesseeds.net/23.
  • MrFishHat
    MrFishHat
    • 505
    Lower the engine with shorter motor mounts? Mill off some of the LIM and plenum you have? re angle the throttle body so that it comes down a bit lower? Im sure if you did all those you could get away with a little scoop instead of a crazy cowl.
  • fyneyoungstunna
    fyneyoungstunna
    Member
    • 46
    #5
    The thought of shorteneing the plenum crossed my mind. has anyone tried this, or any thoughts on doing this?
    also do any of the other gen maximas have a shorter LIM?
    i know the s12( 200sx) one will help a bit.
  • cltcmmder17
    cltcmmder17
    • 342
    #6
    Sheet metal intake? Can shorten LIM at the same time. and bring the throttle body down at a differern't angle.
    Originally posted by StreetFighter
    I don't build my car to keep up with some jackass with more money than me. I build my car because it's never enough, and I want more.
    "Front wheel drive is for the feeble." -Jeremy Clarkson
  • fyneyoungstunna
    fyneyoungstunna
    Member
    • 46
    #7
    I stumbled across some custom intakes on another site. Could be g good step in the right direction. I'm looking at how to shorten the lim atm as well, anyone done this?
  • NissanXRMA
    NissanXRMA
    • 3245
    #8
    I think by shorting they're talking about milling off the top?
  • fyneyoungstunna
    fyneyoungstunna
    Member
    • 46
    #9
    ^ yeah. I wonder if a snubbed lim would hinder performance significantly. I can see this is gonna take some brainpower.
  • SATAN
    SATAN
    • 6782
    #10
    There was a member on NICO who did this. I can't remember his name though. I think it was about a year ago but could be wrong.
    I would go wtih shortening the motor mounts. You can lower the engine 1.5" in a z31 by doing this.
  • fyneyoungstunna
    fyneyoungstunna
    Member
    • 46
    #11
    im looking for info on nico now. but if you guys got anything id appreciate the help.
  • fyneyoungstunna
    fyneyoungstunna
    Member
    • 46
    #12
    i read about the z32 trans swap onto the vg30e. The person(s) doing this used a tt trans, i have an na trans, I dont think there is much difference though.
    another place i asked mentioned using the z32 tt crank in the vg30e(t) to help with the trans swap so that you could just use the tt clutch and flywheel.
    i was reading on going from 30e to 30et. Im assuming since this is going in a z32 i wont need any of the body mounting parts associated with this, or more directly put, i just need the plumbing, manifolds, turbo, and associated hoses and that.
  • Rick88ss
    Rick88ss
    • 2433
    #13
    try shorter motor mounts and a Z31 upper plenum/intake.
    Are you using the Z32 or the Z31 transmission?
    How does the shifter line up if you're using the z31 transmission?
    Shiro #443
  • fyneyoungstunna
    fyneyoungstunna
    Member
    • 46
    #14
    z32 trans.
    i dont have a z31 trans to testfit. into the car so.....
    Ill have to research on who makes mounts that are shorter than stock.
    someone mentioned to me using the 3rd gen maxima intake. I might go full custom if i cant find a solution though.
    the buildup of the engine itself is gonna take a month or two. i think i have already found a bare block so let the games begin.
  • Rick88ss
    Rick88ss
    • 2433
    #15
    there are some z32 motor mounts on ebay. The seller says he can make them whatever size you need
    Shiro #443
