Water/ alcohol (Methanol) write-up
bobby17772Junior Member- 28
oh because I was reading that to get the best results you should tune but I couldn't really find to much besides what was on turbomirage but still. -
There is SOO much information out there about Meth/alch/water injection. Pre turbo and post turbo.
Turbobuick.com
aquamist forum
ausrotary/rx7club
dsm forums
There is TONNNSS of information out there, enough to read around the clock for a whole month.
Buy this kit and you will be g2g.
http://wannaspeed.com/index.php?main_pa … cts_id=18189' Turbo-R.I.P. (scrapped)
maverickxeoSenior Member- 650
If someone says they 'tune' for meth injection, basically they play with timing and boost. Youll have a higher octane fuel, and the IAT will be quite a bit cooler, so in theory, you can make more power when it is optimized for the meth injection. I personally would NEVER 'max' the injection system though.bobby17772 wrote: oh because I was reading that to get the best results you should tune but I couldn't really find to much besides what was on turbomirage but still. -
PulseCodeSenior Member- 1522
You "tune" your car for a water/ methanol system the same exact way you "tune" your car when you add an intercooler. :nanan?re
This of course is for a BASIC water/meth. install. All you doing is adding a system that reduces intake temperatures.
You CAN set up a water/meth. system to work alongside or within a tune for those trying to milk every last HP from their engine.
For the most part, the addition of a water/methanol system, as discussed in this thread- is to reduce intake temps at a FIXED rate.Everything is Meaningless. -
TurboZcaRSenior Member- 302
Do you have this kit? or have you heard of anyone using one?Black 89Turbo wrote: There is SOO much information out there about Meth/alch/water injection. Pre turbo and post turbo.
Turbobuick.com
aquamist forum
ausrotary/rx7club
dsm forums
http://wannaspeed.com/index.php?main_pa … cts_id=1811985 300ZX Turbo- Wrecked R.I.P.
-Stock
04/87 300zx Turbo GLL- Project Car/Daily
-Built Heads, Cams, HX35....etc.
2007 Dodge Ram 1500 SLT Quad Cab w/Hemi- SOLD
-Banks Full 3in Exhaust, Edge Evolution Tuner Chip, K&N Cold Air Intake, BBK 90mm Throttle Body, Full JL Audio Sound System(speakers, amps, subs) Pioneer Touch Screen Head Unit
2014 Chevy Cruze Lt RS- Daily
-Stock 1.4T Autotragic
