How-To: Installing a 2005 Nissan Titan 150 amp Alternator
amrebootBanned- 9875
I have a very sketchy pic that I drew up in MS Paint on how to use stock bracket without the metal extension....Originally posted by les_joey_paulCan I use the smaller heim joint and mount from the oem bracket mount? I'm not really in a position to make a little metal extension. Unless you can make an extra one to send me lol.
I'm getting ready to compile my parts for the upgrade.
Don't criticize me for my awesome drawing…
floridaZSenior Member- 2781
Get a heim setup like… 1"-1.5" shorter than what I used. You should be able to get one with a smaller ID, which might bring the entire thing's size down where you don't need to space it out from the alternator body. If it runs from the oil pump bolt to the alt it requires no bracket/extension.Feedback- viewtopic.php?f=18&t=19840
This is exactly.Originally posted by amreboot View PostI have a very sketchy pic that I drew up in MS Paint on how to use stock bracket without the metal extension....
So the adjuster bolt just screws into the alt that way without issue?http://z31performance.com/showthread…2-2-(-now-NA2T
My build thread (: -
Sweetness. And I need to extend the wiring harness too. The white wire that leads back to the battery positive, that looks like 10 gauge to me. Is that accurate? I was planning to add an extra foot of wire to the harness that runs across the width of the engine. I want to solder 10 gauge to the white, and I guess 14 for the rest.http://z31performance.com/showthread…2-2-(-now-NA2T
Axel kainModerator- 1221
I'd run a beffier wire from the alt ring to battery, def not 10 ga.Damn dirty angels....these cars!
sigpic -
I'm only adding a foot or so. Although. .. does that wire go straight from the alt to the battery? I could probably make my own like 4 gauge short wire instead of extending the already long harnesshttp://z31performance.com/showthread…2-2-(-now-NA2T
pretty sure it's from alt through the fuse link box, then to the battery, although I'd rather run a larger gauge, and lug wire directly to the battery, with a more appropriate size - real- fuse. I plan to do this on whatever street car I wind up installing another alt on. as the current install on the race car, it only has lights, and fans to power…Damn dirty angels....these cars!
sigpic -
The stock length will work, but the extra foot would be really nice. Although, for me the big obstacle for the install was wiggling it past the radiator.Feedback- viewtopic.php?f=18&t=19840
It's already a super tight fit with just the swapping alternator to the other side from na2t.http://z31performance.com/showthread…2-2-(-now-NA2T
NissanEggSenior Member- 5220
I ran a secondary power wire from the battery positive to the alternator post when I did my 350Z/G35 125A alternator upgrade. I didn't trust the factory wire to support that kind of load, so a second wire parallel to the factory splits the load and should never have any issues.
AlloutSenior Member- 182
Dimensionally, how much larger is the Titan alternator vs. Stock - roughly?1986 NA - Purchased by me in December 1985
Working on VG33 - NA to Turbo
Tokico Illuminas w/ Eibach Springs
88SS Sways -
cavalier0Junior Member- 4
hey, so quick question on this, i have a mechanic friend of mine doing this swap and he said that i need a voltage regulator connector for the titan or something like that in order to hook it up all the way
anyone have any idea where i can pick one of those up? -
Not needed. It's a pure electrical plug and play using Z31 harness. The voltage regulator is inside the alternator.
