damn...i wish i had analog..i hate digital
Nicest interiors
Hey now, don't hate on the digital. I like the uniqueness of the dash. And when it works (which mine has, for the most part), it's great. Gets comments all the time.
Badboyz,
I like the blue, very cool. The only thing is, doesn't it kill your night vision? I left mine green so that I could still see at night since this is my DD. That's why most stock dashes are green or red (so I hear). Regardless, very cool.1985 NA 300ZX
Original Stock
redcbs wrote: Hey now, don't hate on the digital. I like the uniqueness of the dash. And when it works (which mine has, for the most part), it's great. Gets comments all the time.
Badboyz,
Badboyz,
I like the blue, very cool. The only thing is, doesn't it kill your night vision? I left mine green so that I could still see at night since this is my DD. That's why most stock dashes are green or red (so I hear). Regardless, very cool.1uz Swapped, lowered, flaked out '86 z31
Custom vg30et tube chassis drift exocet project
Glad to hear they aren't aqua. :-D
Yes, the digital may not be as accurate 100% of the time, but the speedo, oil, and rpms are always working (fuel, engine temp, and battery have a little character) Also I know the car well enough to know when something is up. And since ive replaced the fuel sending unit twice, I just keep track of mileage.
As for the leds, I replaced each footwell light with two leds. The dome light has 5 leds similar to a dice configuration. I left the maplights alone because, occasionally, I need white light in my car. You'll have to give me a bit of time to get pictures of the assemblies as I'm fixing to move back home in two days.
To keep you till then, the dome light is actually not mounted to anything. It sits right on the dome cover, no problems. The two footwell lights, I took some aluminum sheeting and cut/bent it into a box similar to what the stock light sits in (my circuit board/led assy was just a tad too big for the stock box). I left a little fin and drilled a hole in order to use the stock screw to secure it. again, no problems. I'll try and get those pics to you as soon as i can, but life may be hectic for a bit.1985 NA 300ZX
Original Stock
ok sweet, i did the same thing for the foot wells lol, and i will be doing the dome light soon, not rele too worried about the pics so you can take your time.
I live in lake alfred just outside of orlando, but im in tampa right now, yea pensacola is about 6-8 hours from here.1uz Swapped, lowered, flaked out '86 z31
My LED "footwell" lights ...
LED Dome light ..
Door light..
Check my Z Garage link (below) for more pics of the interior ...'84Z31 GLL turbo|theZenthusiast site: http://www.thezenthusiast.com |
Originally posted by maroneePS - by the way your Z31's famous here in japan, dude!!
inqui-Z-tor wrote:
LED Dome light ..
[quote]badboyz31 wrote:Originally posted by inqui-Z-torLED Dome light ..
how did you wire up the dome light? too come on with the other lights or too come on with the door and switch?
I can turn on/off via switch; and/or via door ... the LED array was designed/built by xinxspuz ..
http://88hybrid.com/forum/viewtopic.php ... hlight=led
MSA now markets LEDs for dome lights ..'84Z31 GLL turbo|theZenthusiast site: http://www.thezenthusiast.com |
[quote]inqui-Z-tor wrote: [quote=badboyz31]Originally posted by inqui-Z-tor:564acLED Dome light ..
MSA now markets LEDs for dome lights ..[/quote:564ac]
sweet thanks im deff gonna have to pick some up lol i will make my out board if i have too, but some companies sell them as a board, should have them soon though1uz Swapped, lowered, flaked out '86 z31
Towards the LED's
I bought this kit for $25 and fits 5 different style bulb bases.
http://www.superbrightleds.com/festoon.html#U-PCB
It was daylight out when I took these pictures. Ill get night pictures soon...if WANTED?
12 HIGH POWER LED's
12 LED AMBER BULB...OFFSET, its the reason the light is bright in the corner...
I have these for my footwell/courtesy lights
3 HIGH POWER SMD LED's
SCROLL DOWN TO BOTTOM OF PAGE
http://www.superbrightleds.com/mini-wedge.html
