Chrome Door panels
RMWheeler300zxMember- 40
Chrome Door panels
My 1989 Turbo GLL has these chrome panels on the sides that I have not seen on any other Z. Does anyone have the run down on them? Were they factory? A rare option? No longer produced aftermarket? -
TomakzeSenior Member- 624
Huh, So I wasn't the only one with those. I had them on my car when I got it, but I removed them. Mine had some cracks and chips. I would guess they are either dealer installed, or aftermarket. They are glued on, and easily removed with a plastic scrapper tool and a heat gun."Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you…"
-'68 Datsun 1600 Roadster
-'85 300zx Turbo
VenSenior Member- 510
Chrome Doors
I'm glad to report both sides look pristine like that. I was thinking of repainting the car black, then reapplying them if possible.Tomakze;341809 wrote: Huh, So I wasn't the only one with those. I had them on my car when I got it, but I removed them. Mine had some cracks and chips. I would guess they are either dealer installed, or aftermarket. They are glued on, and easily removed with a plastic scrapper tool and a heat gun. -
Kick panels .. Aftermarket ..
80s version of today's vinyl graphics!'84Z31 GLL turbo|theZenthusiast site: http://www.thezenthusiast.com |
While easy to remove, I'll warn they don't like to come off intact if you plan to keep them. Mine exploded into 10,000 pieces."Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you…"
-'85 300zx Turbo
