link3354 link3355 link3356 link3357 link3358 link3359 link3360 link3361 link3362 link3363 link3364 link3365 link3366 link3367 link3368 link3369 link3370 link3371 link3372 link3373 link3374 link3375 link3376 link3377 link3378 link3379 link3380 link3381 link3382 link3383 link3384 link3385 link3386 link3387 link3388 link3389 link3390 link3391 link3392 link3393 link3394 link3395 link3396 link3397 link3398 link3399 link3400 link3401 link3402 link3403 link3404 link3405 link3406 link3407 link3408 link3409 link3410 link3411 link3412 link3413 link3414 link3415 link3416 link3417 link3418 link3419 link3420 link3421 link3422 link3423 link3424 link3425 link3426 link3427 link3428 link3429 link3430 link3431 link3432 link3433 link3434 link3435 link3436 link3437 link3438 link3439 link3440 link3441 link3442 link3443 link3444 link3445 link3446 link3447 link3448 link3449 link3450 link3451 link3452 link3453 link3454 link3455 link3456 link3457 link3458 link3459 link3460 link3461 link3462 link3463 link3464 link3465 link3466 link3467 link3468 link3469 link3470 link3471 link3472 link3473 link3474 link3475 link3476 link3477 link3478 link3479 link3480 link3481 link3482
What would cause this ecu related failure?
  • Z_Karma
    Z_Karma
    Administrator
    • 3318
    I've been running an 87na 5spd fed ecu in my 84T, 5spd turbo for a month or so
    and had no problems other than an unstable idle which was minimized by adjusting the
    idle set screw on the TB and unplugging the AAC valve. It would idle high ~1200 with the AAC plugged in,
    and the instability would drop it to 500 sometimes and other times smoothly at 700.
    Today after work i go to start it and notice a high pitched constant whine from the fuel
    pump. The car starts up fine, but now in addition to the whine, It has a rough irregular idle,
    revs rough and belched blueish rich smoke out the back. I also do not hear the audible
    click of the fuel pump relay from the passenger B pillar. I always listen for that.
    After unplugging a few things and replugging them in with no change (AFM, O2 FPR) I am
    about to give up. As an after thought, i plug in the original ECU. It starts up fine and the
    noise from the fuel pump is gone. The car gets me home but with the same problems that
    running the 84T ECU had, hesitation, acceleration doesn't feel as smooth as with the 87na ECU.
    Also the AAC is plugged in and the 84T ECU doesn't jack up the idle.
    I'll check the codes later tonight.
    I hate this shit…
    Any ideas?
  • Careless
    Careless
    • 13279
    that is odd… one ecu makes the pump whine, the other doesnt. but otherwise they operate the same?
  • Z_Karma
    Z_Karma
    Administrator
    • 3318
    The 84T ECU, when installed, causes the car to hesitate on acceleration where you can feel it kind of holding back when compared to the 87na.
    It also will only start on the 3rd try. It could be related to this http://z31performance.com/showthread…ECU-pcb-repair
    I haven't really dug down deep into troubleshooting as i've been focused trying to get the other SS running before fall.
    But i did bring the ECU into my lab this morning and found a fair amount of water damage to the PCB. I would suspect that the corrosion and rust
    could be causing intermittent shorting which may be the problem with the erratic idle and now the fuel pump issue. My employer builds industrial
    high power UV LED lightsources that replace arc lamp technology in large format printers. It's a pretty harsh environment and I see a fair amount
    of returned demo units where it looks the whole lamp assembly was dipped in something caustic.
    Sorry for the quality, my lab camera is over 7yrs old..
  • Careless
    Careless
    • 13279
    that'll do it. lol
  • Augustus Maximus
    Augustus Maximus
    • 1739
    #5
    Brush it away and apply a coating of polyuretane to the affected area.
    Cha iro
    at least you gave it a whirl.
  • Careless
    Careless
    • 13279
    #6
    wouldn't even bother with it. some of those components can be damaged, but still functional to a certain degree.
  • G-E
    G-E
    Junior Member
    • 6320
    #7
    Augustus Maximus;343351 wrote: Brush it away and apply a coating of polyuretane to the affected area.
    That's a really dumb idea, it's already rusting
  • FrozenZ
    FrozenZ
    • 584
    #8
    G-E;343357 wrote: That's a really dumb idea, it's already rusting
    Seriously, this can work. I've done it on mixers and old power amps (though those were usually intended to be somewhat serviceable, which I don't think the ECU is.) If any of the components that actually provide logic were damaged the thing would probably just be a brick. Sometimes damaged connections or traces will work fine if they can be kept absolutely dry. Or you could get in there and start trying to replace corroded jumpers and caps/resistors. I have seen much worse boards on audio gear brought back from the dead.
    However, given what an ECU costs and the fact that you apparently have a leak into your ecu compartment, I would try to fix the latter first and just get a different ECU. There's no sane argument for trying to fix a rusted PCB in this case if you actually want a running car anytime soon
  • Z_Karma
    Z_Karma
    Administrator
    • 3318
    #9
    I most likely bought it like this. I can clean it up using tools at work, (we see corroded PCB's a lot) and conformal coat it but
    i dunno if i would trust it. That's why i kept the stock ECU behind the seats…insurance.
  • reddzx
    reddzx
    Senior Citizen
    • 6440
    #10
    Is this the one you just got from me?
    1991 Hard-body 2WD
  • Z_Karma
    Z_Karma
    Administrator
    • 3318
    #11
    Tim, it was another one that i was using when this happened.
    I attributed the failure to the corrosion i found and installed yours this morning before work.
    I made it to work fine, idle was still bottoming out at ~500rpm before stabilizing at 700
    Other than that it ran great.
    However, after work, it tried to cut out and started sputtering again with the ECU i got from you.
    Luckily i was really close to home and nursed it the rest of the way.
    I noticed a commonality, both times it happened was immediately after i was aggressive on the throttle, under boost.
    First 87na ECU,
    The first time it cut out a few days ago was just after lunch and i was accelerating into a turn to beat a light.
    I noticed it slightly trying to cut out before i parked it but didn't think anything of it until after work when the pump whined
    and it wouldn't stay running.
    Second 87na ECU,
    Gave it some gas and was under slight boost when i felt the cutting out happening again. I pulled into the side street and it
    kept sputtering, trying to die. I had to keep the rpms up and california stop a stop sign to make it home, that's where i noticed
    the whine of the fuel pump again.
    What the hell
    (I park the car and go inside to drown my sorrows in Minecraft for a few hours)
    EDIT:
    So before posting the above, i think "i should check the codes on the 87na ecu"…(z31.com "did you check the codes before posting" flashbacks)
    I go out to the car and I get this:
    1 long Green
    3 quick Red and Green
    4 quick Red and Green
    5 quick Red and Green
    1 quick Red and Green
    1 quick red and Green
    1 slow red and Green.
    This makes no sense.
    And the car doesn't start, no fuel pump whine anymore when it primes and the B pillar relay turns it off like normal.
    Okay, plug in the 84T ECU, same thing… relay works, pump comes on with no whine..still no start, cranks but doesn't even try to catch.
    What the diddly?
    Hmm..I can smell raw fuel smell from the exhaust pipe.
    I pop the hood to see what i can see and casually pull the vac tube from the FPR.
    Gas comes out of it. DUN DUN DUUUUNNNNN!!
    Okay, my stock FPR (replaced in 1995) took a shit, boost probably pooched the dying diaphragm.
    But what then would cause the fuel pump whine? (forgot to mention it's a Walbro 255, tank is 3/4 full of midgrade)
    Does the fuel circuit in the 87na drive the pump differently/harder than the 84T or something (i don't see why it would)
    I'll start with replacing FPR i guess (hooray for stockpiling spare parts, i have 2 spare fprs…somewhere)
  • Z_Karma
    Z_Karma
    Administrator
    • 3318
    #12
    Last night I replaced the FPR with a spare and had to crank it for 10-15 seconds but it finally started and chugged for a few minutes
    before coming to a stable idle using the 84T ECU. There was some smoke coming from the drivers side exh manifold area for awhile.
    I got under it but couldn't see where the source was. My motor is really clean so it should have been easy to find.
    I'm thinking the fuel that was sucked into the intake thru the leaking FPR got to the exhaust manifold gasket and burned off.
    I couldn't see under the manifold shields so i'm hoping that theory is correct.
    I did an oil change just to be sure and afterward it idled much smoother. I'm sure a fair amount of gas made it into the oil.
    Drove it around the neighborhood and it ran fine. Checked for smoke under the hood and found none.
    I think I'll try the non-corroded 87na ECU tonight.
    I'm hoping all of this was just a bad FPR and i can go back to the 87na ECU.
    I'm still confused by the weird ECU code thing though.
