Help Identifying Dash Light
LA KINGSMember- 43
wtf does this light mean. my car seemed like it was running hot so i did a radiator flush on it at work and a few days later this light started to pop on and off randomly.
reddzxSenior Citizen- 6440
That's the coolant level warning light. It comes on when the coolant in the reservoir tank drops below the minimum level mark
1991 Hard-body 2WD
Dr. Pepper PhD.Senior Member- 1301
Or that it was his birdcage light… And that his bird got out and needs to be found.88SS - #300 - http://z31performance.com/showthread.php?18360 -
I've done my good deed for the month now, Noobs watch out.
1991 Hard-body 2WD
But the month is almost over. That is hardly any time for shenanigans88SS - #300 - http://z31performance.com/showthread.php?18360 -
Dave-DSenior Member- 397
Another thread full of grumpy old men being a bunch of wise-asses....I love this forum!
OP go top off your coolant.....Black 1985 na/coupe brought back from the dead.
2000 frontier for work.
2004 PT Cruiser for gettin' grocery's. -
fairladyloverSenior Member- 334
ROFLMAO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!Dr. Pepper PhD.;345559 wrote: Or that it was his birdcage light… And that his bird got out and needs to be found.
hahahahahahahahahahahaha
best day of my life -
aZinMASenior Member- 146
FlyingTSenior Member- 1095
While you are at it, what is the light that looks like a tea kettle with a drip coming out of the spout? Just above the oil pressure. Tea time anyone? LOLRestore it, Don't crush it. They don't make them like this anymore.
Scott
93 NA Babied
spoonfeed fest is over noob. lolFlyingT;345601 wrote: While you are at it, what is the light that looks like a tea kettle with a drip coming out of the spout? Just above the oil pressure. Tea time anyone? LOL
1991 Hard-body 2WD
The genie used to live in the cage, but when it got moved to the lamp, Nissan installed a bird in the cage rather than just remove the cage. Re-purposing parts is where Nissan excels.88SS - #300 - http://z31performance.com/showthread.php?18360 -
LA KINGSMember- 43
my issue is that the coolant is full. I used the machine that sucks everything out and collapses the hoses and then pressurizes the entire system back up and this light still comes on when I hit bumps.Dave-D;345580 wrote: Another thread full of grumpy old men being a bunch of wise-asses....I love this forum!
OP go top off your coolant..... -
you have a bad sensor in the tank
1991 Hard-body 2WD
LA KINGSMember- 43
The birdcage represents the coolant overflow tank, pull it, clean the sensor and replace it if it continues to indicate low coolant.
How hard is that to understand?
1991 Hard-body 2WD
