Babydude: where did you learn about doing that? Was it from that forum that I'm talking about?
Been painting the 84T with a roller . . .
jjewell wrote: this is where i originally heard about this type of paint job.
http://board.moparts.org/ubbthreads/sho ... art=1&vc=1http://www.vgpowered.com
raidon84300zx wrote: For paint I'm using Rust'O'Leum oil based paint.
To apply the paint I'm using a high density foam roller for the big areas, a foam brush for the hard to reach areas, and LOTs of paint thinner and mineral spirits to thin the paint out to the consistency of a little thicker than water.
For the sanding department, I'm using 500 to 800 grit sanding in between coats, 1500 to 2000 grit for final sanding, and then polishing compound to finish it off. Have to wait a month for the paint to dry rock hard before I can apply the wax.
I've been also considering the applying the oil-based clear coat available from Rust'0'Leum to bring out even more of the "bling"
84-86 Nose. I can't wait to see it all waxed after it's cured.http://www.vgpowered.com
MikeZ wrote: Mitsu. Starion wheels.http://www.vgpowered.com
MrwassmanNA2T wrote: We tried this on by buddies supra
about as far as he got.... gave up on the shine
why people do that to their flip up lights is beyond me.http://www.vgpowered.com
bump . . . finished the rear bumper . . . working on the driver's side quarter panel.
It's been awhile since I could get back into painting since the weather has been sh*tty and I'm painting outside.[strike:ff0tp92h]1984 300ZXT[/strike:ff0tp92h]
2000 Porsche Boxster
2007 Toyota Yaris
