Just got his custom Moser axle stubs and companion flanges installed(I'll be going with Modern motor sports). Yes the guy that everyone is skeptical if his car actualy makes 750-800whp.
So heres the deal, Paid $1500 total for the conversion including bearings and spacers. Got it all installed and is now snapping the actual CV shafts. He said he is snapping it by the differential side of the shaft where its actually a smaller diameter part of the shaft right before it goes into the boot. (I think this is where he was talking about) What he is doing about this is he is Taking a pipe that is .003" larger I.D. than the shaft, then cutting each end staggered(like the top of a castle) then sliding the pipe over a good axle somehow and welding the ends(the castle part) to the axle.
I havent heard if this works yet and many of you may not care just yet as you will most likley only be breaking stubs as for now. BUT as I find out more or learn more from my own experience I will be bumping this thread.
You can see here where it is thinner. If this is the spot he is talking about I dont know, I have to find out more info.
