Refresh
This website z31performance.com/forum/z31-performance-upgrade-forums/driveline-aa/1268-destroyed-the-fs5w71c is currently offline. Cloudflare's Always Online™ shows a snapshot of this web page from the Internet Archive's Wayback Machine. To check for the live version, click Refresh.
Destroyed the FS5W71C!
  • Destroyed the FS5W71C!
    My Front input shaft seal is leakign tranny fluid... ive known this... this is why my 1 year old exedy clutch is slipping on my 86NA.
    Anyway...
    Through the year or so that Ive had the car with this clutch just installed, that seal got replaced. But I dont know but my mechanic somehow didnt install it right and it has been leaking ever since.
    Last week by a years worth of leaking slowly it has gotten itself up to a point where it started whining... REALLY... REALLY.... REALLY loud. Im talking about... on the freeway... going 50mph... the whine from the tranny was WAYYY louder to even hear my engine (I have a 2.5 inch straight through exhaust) and to hear my cd player at the same time...
    Anyway...
    I had to go to work ALL DAY everyday for a couple of days so Ive been driving with it just about almost dry...
    Today I FINALLY (after 3-4 days of driving it) filled it with 85-140 weight (Meets all GL Specifications) LUCAS tranny fluid.
    I started the car and drove it around, and the whine went away about 40%, but its still EXTREMELY loud...
    What have I done?
    oh yea... Also... the whine ever since it first started a week ago is ONLY existant upon ACCELERATING, upon deceleration it is absolutely completely gone, and its also the same today even after I filled it.
    WHats the deal?
    1SIKZ31 -86 SlickTop- R.I.P. 03/01/10 ... Parted out :-(
    ... New Project: LS1 Miata. Complete. 510whp. 2500lbs.
    You've done damage by running it dry.
    You can pretty quickly add fluid to it by pulling the shifter out and dumping a bottle in that way.
    2009 370z touring/nav/sports
      Your bearings are most likely shot, meaning your axial play is making the gearsets mesh improperly... find another one and swap it... they are not worth rebuilding unless you have a lot of extra money and time floting around.
        That sucks man, My gearbox has a whine when it is cold
          Yep, I agree on the bearings. I bet the shafts where the bearing ride are worn, too. Just replace it. I'll see if I can locate one for you.
          Chuck Stong
          http://www.300-plus.com
            Update:
            just went WOT on the freeway and went through 3rd, and went halfway through 4th (110mph) and shortshifted in 5th and went WOT. (yes stupid of me)
            and I all of a sudden the tranny got instantly ALOT louder so I of course got scared and slowed down and now its LOUD at ALL speed ranges, before this incident it made very little to no noise up until 40mph from 0, and then the noise almost went away again at 65mph and up. After doing this WOT run now it makes a LOUD whinign and rumblign sound at ANY speed.
            When I say loud, you guys have NO idea how long it really is. its freakign LOUD.
              Like a race car with straight cut gears and a dogbox loud?
                1SIKZ31 wrote: My Front input shaft seal is leakign tranny fluid... ive known this... this is why my 1 year old exedy clutch is slipping on my 86NA.
                Anyway...
                Anyway...
                What have I done?
                WHats the deal?
                let me get this straight... you had a leak.. the leak was never fixed properly and you ran the tranny dry.. now it makes noise.. you added fluid and it makes a little less noise. then you ask "whats the deal"... what exactly are you trying to figure out here?
                  z
                    zmech wrote: That is more nicely put than what I was thinking.
                    Zmech
                    yea.. i try to be nice on this forum... maybe we should just redirect these people to z31.com and then let loose on them..
                      You might need one sooner than Feb. Plan on it becoming undrivable sometime soon. I would get another tranny before anything else.
                      Chuck Stong
