Refresh
This website z31performance.com/forum/z31-performance-upgrade-forums/driveline-aa/1280-smell-from-rubber-insulator-on-shifter-assembly-solutions is currently offline. Cloudflare's Always Online™ shows a snapshot of this web page from the Internet Archive's Wayback Machine. To check for the live version, click Refresh.
Smell from rubber insulator on shifter assembly...solutions?
  • Smell from rubber insulator on shifter assembly...solutions?
    Anyone else have this problem? On road trips, when a mass of heat rises from under the car and hits the rubber insulator on the shift assembly for a long period of time, a smell starts venting.
    I've removed it completely before. The smell goes away but heat and sound now enter the cabin. Is there some sort of spray I can nail this rubber piece with to keep it from spewing a smell when it gets heated?
    2008 BMW E92 335i 6MT
    Re: Smell from rubber insulator on shifter assembly...soluti
    Signal 12 wrote: Anyone else have this problem? On road trips, when a mass of heat rises from under the car and hits the rubber insulator on the shift assembly for a long period of time, a smell starts venting.
    Man! I had that same problem when I pulled mine out, cut it down and welded it back up. AHHH THE SMELL!!!! /vomit. Dont know what to tell you though. Pull the shifter burn out all the rubber heat insulator stuff and then weld it back together? thats what I did when I shortened it.
      im not 100% shure in the difference of the FS5R30A to the FS5W71C but i know the 71C has a little vent at the top, possibly hot trans smell? time to change the trans fluid?
        Nothing that a ZipTie can't fix. As long as the rubber boot and steel plate that install from the interior side are in good shape, just add a little sealant to make an absolute seal from the rubber to the chassis and a ziptie on the shifter shaft portion of the rubber to make a good seal.
        I have had cars with next to nothing left for the actual boot sealing from the shifter to the transmission. Following what I am advising solved any smelling issues. What was left in regards to the silly boot for the shifter to the trans was merely a dust cover and not enough to get a ziptie on for locking the rubber boot to the tranny. No harm other than vapor/smells easily exiting.
        Dan
        I am here to help...
