Get your aftermarket flywheel and pressure plate balanced!
jjewellSenior Member- 402
i just had mine done for $75 and it will be done everytime for now on. what a difference! the car runs much smoother and this is with a fidanza flywheel and act clutch the whole assemblie was only out about 7 grams total but the difference is night and day.
i decided to do this after jason had his run in with the exploding flywheel, and i'm very glad i did.
boost. does a body good! -
Re: get your flywheel and pressure plate balanced
Good advice that needs to be repeated. ALWAYS get the assembly balanced when you buy any aftermarket flywheel. In the case of fidanza and most others they are NOT balanced from the factory and not getting them balanced on your own is a recipe for disaster. Even if it's just your main bearings that suffer because of the imbalance, it's worth the time and money to get it done right just to decrease the probability of failure.
I'm surprised yours was only 7 grams out, mine was double that. Another similar thread for reference:
viewtopic.php?f=1&t=708&p=55810&hilit=flywheel+bal ance#p55810 -
so jjewell you were driving with what you had, then took it out for balancing, then reinstalled....
and the car is much less noisy or what exactly is the feeling? -
MachZSenior Member- 386
I think that comparison shows it pretty well. The flywheel should be pretty well balanced, just like a wheel, but when you start putting stuff on it can become unbalanced.
I just picked mine up from getting balanced. About 8 grams off, mostly on the pressure plate, $70.
[quote]G-E wrote:you missed the fact that it was a question (I wonder how…), as I've heard the same assumptions and I do question it as well, it's like v8 folklore, no one understands it, but everyone has rules of thumb they swear by[/quote:5d5ce]Originally posted by got boost?:5d5ceGE you don't know what the heck you're talking about. This needs to be emphasized: LISTEN TO SATAN! It's amazing how many people (GE in this case) trade in stupid/wrong info and baseless assumption on the internet. The harmonic damper is a necessary part of a properly functioning engine.
You were a little vague in your post… it's internal vs external balance you were talking about, and confused it with balancing a rotating assembly on the front or back of the crankshaft… Generally speaking for an external balance they balance both the harmonic balancer and flywheel with the rotating assembly. For an internal balance, the rotating assembly is balanced on its own, and flywheel/harmonic balancer are then balanced on their own so the entire assembly is assumed to be in balance. There's a few other combinations and ways to do it, obviously, but I've never heard of trying to 'balance out' a flywheel using a harmonic balancer. The concept seems a little ludicrous even as they are on opposite ends of the crankshaft. -
GregmaticSenior Member- 2193
Just got my Fidanza and ACT done and........................
Holy Shit! I'm a believer!
They took a ton of material off one side of the ACT and added some on the other and had to weld some bead on the pressure plate to get it balanced. I don't mean a few milligrams, I mean a lot of material. Pics to follow soon…
Some performance engine machine shops and most clutch shops. South Bend Clutch will also do it for you if you buy one of their DXD series clutches.Z31SPL wrote: where can i get this done? A machine shop? -
SlydwyzSenior Member- 687
Just because I like to stick with GIVING BACK to the Z community or sticking with its sellers I'd say buy yourself a Fidanza flywheel through Jason ( http://www.Z31Parts.com ) and a DXD (South Bend Clutch), and then possibly have Jason or yourself have the fidanza flywheel DROP SHIPPED to South Bend to have everything clutch and flywheel balanced together, this way it'll save you some time going to a shop and getting it done, so when it comes, its ready to install (RTI), but thats just me.Gregmatic wrote: Just got my Fidanza and ACT done and........................
They took a ton of material off one side of the ACT and added some on the other and had to weld some bead on the pressure plate to get it balanced. I don't mean a few milligrams, I mean a lot of material. Pics to follow soon…Pictures yet?
AE84 sk1Lz31 wrote: damn, that is pretty fucking stupid how we have to balance that shit. Fuck, i wonder if my auto mechanics teacher would have the equipment to do this. I wonder if it is that serious of a problem if you just get one from eBay and throw it on. I got a turbo model. Has anyone dealt with any of the clutch kits on this here page?
http://search.ebay.com/search/search.dl … category0=
a small selection for turbo models but any experience with any of these clutches? or any good/bad reviews? Thanks in advance. My clutch is out and is going to get replaced in the overhaul process.
Maybe get more reviews and such before making a choice…
P.S. Go with Motul Clutch/Brake Fluids, said to work wonders with Z clutches..(Stated @ MSA) -
gardner86zxSenior Member- 381
my stock flywheel and dxd stage 2 pp was out by 7 grams86na2t + holset
feedback
Just had my Fidanza flywheel balanced. It was used for about only 160 km.
3 grams out. Balancer guy was surprised. -
vagabondSenior Member- 3455
PulseCodeSenior Member- 1522
I called around here in Greenville SC, to get this done before my NA2T and was told that it had to be done while they were installed on the car.
My sticky shifting is still not fixed so I think I'm gonna find a good clutch shop that will balance mine too, while they have it all apart.
If anyone knows a good local place to take it for this, (Durkin or Robyr) please let me know. Thanks.Everything is Meaningless. -
That's not true. If your were going for the most extreme balancing and the crank wasn't balanced from the factory, maybe.PulseCode wrote: I called around here in Greenville SC, to get this done before my NA2T and was told that it had to be done while they were installed on the car.
akronzSenior Member- 308
LMAO i just seen a guy explode/grenade his 2010 mustang on the freeway today going about 130 lets just say no scatter shield his hood is garbage along with ALOT of his electics. BEST part he was crying "my mom just bought me this clutch"
http://www.neospeed.freeforums.org
1985 300zx n/aRegretfully Retired
1997 240sx srdetSadfully Sold
(!Attention!) If you have an 85 - 89 thats not stripped out a shell rolling body preferred contact me at330 328 2789 (ask for rick)
