Get your aftermarket flywheel and pressure plate balanced!
862sikSenior Member- 2159
The point being is adding any new clutch/pressure plate/flywheel to the system can put it off balance. It's better to have it done. Had mine done with the chromoly billet flywheel and kevlar clutch from SBC. Happy with the results so far. About to test some power in a couple weeks when I'm home though.862sik wrote: Should one do a factory flywheel and a dxd stage 1?Usual Z31 suspect: Garage Queen (aka broken)
I ended up not doing it.862sik wrote: Should one do a factory flywheel and a dxd stage 1?My Build Thread -
Is the vg30e internally or externally balanced? What exactly do I have to tell the shop to get them to balance it correctlyhttp://z31performance.com/showthread…2-2-(-now-NA2T
My build thread (:
