NIStune M30 type 2 board
  • Rick88ss
    Rick88ss
    • 2433
    On the Nistune website it shows the M30 (VG30DE) using a type 2 board. Is this the Infinity M30 with the VG30E or a JDM model or something with a VG30DE?
    What's so good about the US market M30 ECU?
    Shiro #443
  • aceman
    aceman
    • 1566
    it runs consult like the other 90's nissan. bernard did an excellent write up about 7 years ago.
    Nearly all men can stand adversity, but if you want to test a mans character make him a moderator.
  • Rick88ss
    Rick88ss
    • 2433
    Where's the write up? Doesn't the M30 come with a VG30E and not a VG30DE?
    international seed bank.
    Shiro #443
  • Careless
    Careless
    • 13279
    yes, but its a newer ECU with a couple of good features.
    if you read the M30 ecu sticky, there are some people who got it running and like it better.
    I think I will be making a patch harness soon.
  • shromy
    shromy
    • 2189
    #5
    VG30e
    Hmmm, Whats next?
    84ZXT
  • Rick88ss
    Rick88ss
    • 2433
    #6
    Where's the M30 ecu sticky? I couldn't find it.
    Shiro #443
  • shromy
    shromy
    • 2189
    #7
    I didnt know there was one, if you cant find it by tonight I can send you the basic repin info for it after work. Wanna pm your email to me?
    Hmmm, Whats next?
    84ZXT
  • Guest's Avatar
    Bernardd
    #8
    1
  • Rick88ss
    Rick88ss
    • 2433
    #9
    I couldn't find the M30 ecu sticky.
    Does the M30 ECU use the same CAS as the Z31?
    Shiro #443
  • shromy
    shromy
    • 2189
    #10
    Yes.
    The CAS unit itself is the same for IDK 100 cars. The wheel inside is what makes the signal what the certain ecu wants to see. IIRC it is the same wheel setup in the m30 as the z31. It is as easy as buying a JY m30 dizzy and comparing the 2 to be sure.
    Hmmm, Whats next?
    84ZXT
  • ShamWow
    ShamWow
    • 1905
    #11
    Rick,
    Searching "M30" or "ECU" wont get you results, because the search engine does not allow words of 3 letters or less. Please use google site search, or simply flip back a few pages of the engine management forum:
    viewtopic.php?f=6&t=22569
    viewtopic.php?f=6&t=10646
    http://z31performance.com/forum/viewtop … &sk=t&sd=a
    "produce first.talk second."
  • michaelp
    michaelp
    • 9384
    #12
    LOL @ buying JY M30 parts, more likely to find a Maserati biturbo in the JY than a M30 around here. You guys do realize how rare M30s are right?
    Infiniti M30 = VG30E, "JDM" Model would be the Nissan Leopard available with many engines, from a VG20DE to a VG30DET.
  • aceman
    aceman
    • 1566
    #13
    D and WD21's with MPEFI may do the same thing for you that an m30 ecu would, and there are a ton of those.
  • Careless
    Careless
    • 13279
    #14
    aceman wrote: D and WD21's with MPEFI may do the same thing for you that an m30 ecu would, and there are a ton of those.
    it'd be good to find out if they're basically the same regarding the hardware capabilities.
    another alternative to wiring in an M30 directly to the harness is to get a spare ecu that's broken from a z31, desolder the female ecu connectors, and resolder them onto a project board that you can make a patch harness with in a little box…
    that's what I got, and will be doing soon. Then selling my 87 Nistune ECU and buying Type 2.
  • Guest's Avatar
    Bernardd
    #15
